stevegough
posted on 15/4/09 at 05:03 PM |
engine stand
quickie - when putting engine (red top) on a stand, do you need to remove the clutch and the flywheel or just the clutch?
Engine stand is sealy 450
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
chrsgrain
posted on 15/4/09 at 05:11 PM |
When I put mine on from that end I had to take the flywheel off, but you can put it 'side on' if you find the right bolts and use a few
(small) spacers, makes it easier to work on the end...
Chris
tomgregory2000
posted on 15/4/09 at 05:42 PM |
i had mine on the stand with no flywheel on
stevegough
posted on 20/4/09 at 09:27 AM |
now mounted on stand, clutch removed, but not needed to remove flywheel - just needed shorter arm - to mounting plate 14mm 8.8 bolts so the plate will
still rotate.
Luego Locost C20XE.
