Author: Subject: star headed bolts
omega0684
posted on 20/4/09 at 01:48 PM Reply With Quote
star headed bolts
i came across some 6 point star headed bolts yesterday when taking my mates car apart, like these
where can i get a set of sockets to remove these in future, do they have a specific name, they were a right pain to get out without the proper tools
blakep82
posted on 20/4/09 at 01:50 PM Reply With Quote
torx bolts, you can get the sockets from halfords
they're not particularly cheap though if you just want one or two sockets
vauxhall engines seem to be made of them...
[Edited on 20/4/09 by blakep82]
________________________
deezee
posted on 20/4/09 at 01:52 PM Reply With Quote
Also available at machine mart. They look pretty expensive.
Machine Mart Torx Star
Mr Whippy
posted on 20/4/09 at 01:54 PM Reply With Quote
yeah vauxhall use these throughout the engine, halfords will stock the sockets
vinny1275
posted on 20/4/09 at 02:11 PM Reply With Quote
external torx bits - they also do ratchet spanners with these heads at halfrauds (really not cheap tho!) which is really handy when you can't get a socket ratchet on there (BMW use these all over the place, and you can't get a socket in around the exhaust / Diff if you need to take it off). They get rusted to sh1t as well if they're under the car and just round off - I replaced them all with normal bolts whenever I came across them....
Vince
Miks15
posted on 20/4/09 at 02:23 PM Reply With Quote
You can bllody well say that again! grinder sure came in handy everynow and again!
Mr Whippy
posted on 20/4/09 at 02:35 PM Reply With Quote
Hmm about as bad as Allen key bolts on break calipers which usually rust round inside and end up needing ground off
What’s so wrong with a normal hex bolt that they need to replace them with such rubbish designs?
iank
posted on 20/4/09 at 02:54 PM Reply With Quote
Main dealers charge by the hour?
Hex bolts turn to blobs of rounded off rust given enough time if under the car - ask any mini owner
Anonymous
blakep82
posted on 20/4/09 at 03:22 PM Reply With Quote
yep, no matter what bolts you use, they'll all round off.
i'm actually replacing most of mine with allen bolts, just because they look neater, and are all 12.9 grade
