mr henderson
posted on 28/5/09 at 07:35 PM |
Black and Decker Powerfile
I bought one of these at Stoneleigh, and used it seriously for the first time today when needing to fettle a GRP nosecone
http://www.cbsonline.co.uk/black--decker-powerfile-pwrf-979-p.asp
What a brilliant piece of equipment! I was expecting it to be moderately useful, but hadn't expected it to be so good. I'm still on the
first belt but must have ground loads of GRP to dust with it.
One of the really good things about it is that you don't need as much access to the work as you would if using a sanding block, or drum, or file
even, and I managed to do a lot of the work almost in situ, just wedging the bits apart enough to get the business end in.
Thoroughly recommended
John
blakep82
| posted on 28/5/09 at 07:41 PM |
i've used air powered ones before and was really impressed with them too
________________________
| posted on 28/5/09 at 08:00 PM |
I got one from Amazon for Christmas and agree that they are really nifty bits of kit. I found ebay good source for belts as well.
minitici
| posted on 28/5/09 at 08:39 PM |
I did have a Powerfile but the B&D unit used an odd sized belt (only available from B&D at inflated prices)
I think i'll buy an air linishing tool which uses industry standard belts.
stevegough
| posted on 28/5/09 at 08:41 PM |
Sounds like a good tool - control with quick results - but - don't forget your PPE - mask etc.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
andrew.carwithen
| posted on 28/5/09 at 08:48 PM |
Was the most useful tool I bought during my build. I actually wore out one of the arms (the roller on the end) and had to replace it with a new one I
used it that often.
I also bought belts in bundles of ten off ebay at a much cheaper price than B&D genuine ones.
robinj66
| posted on 28/5/09 at 09:47 PM |
What a great tool - has made many jobs so much easier.
As Andrew says - you can get the belts cheap on Ebay - go for the blue ones - they really do last longer
ReMan
| posted on 28/5/09 at 09:55 PM |
Yep great for fettling grp with minimum of gell coat damage
| posted on 28/5/09 at 10:50 PM |
Here you are,
30p each roughly.
Simon
| posted on 28/5/09 at 11:58 PM |
We must have gone through best part of a hundred powerfiles at work over the last 15 - 20 years.
Thoroughly agree how useful they are.
Screwfix do belts quite cheaply, but they occassionally snap soon after starting use. B&Q do them for about a fiver for three, so avoid like the
plague.
Arms (wheel bearings) wear out as mentioned and they are about £9 and do pads under the arm (£2ish!!/each).
Motor bearings fail, drive from motor to drive pinions also fail.
They do have a two year warranty though so if file breaks and arm's had it, send the lot back and get both replaced.
They are now on 3rd generation so not as cheap as they could be - we were getting the previous models for about £20, which when you consider they are
identical apart from a slightly different external design is a bit unreasonable.
Simon
Fred W B
| posted on 30/5/09 at 04:09 PM |
Mine has just packed up completely, but agree that they work well. Although they don't feel like a quality tool they can do some jobs quickly
that would be very difficult by any other means.
Fred W B
stevegough
| posted on 19/6/09 at 09:11 PM |
Just remembered the above thread .....
I was in B+Q earlier today, and they had a table full of 'special' offers by the door, the B+D powerfile was reduced from £43.95 to
£38.....
......just thought I'd share that with you...
Steve.
Luego Locost C20XE.
| posted on 19/6/09 at 09:18 PM |
How useful are the air 'powerfiles'? They're fairly cheap, and very small, but I don't know how available the belts are.
I have a decent compressor, and I'm unlikely to use the tool away from it.
