Author: Subject: Is there a technique to seprating a type 9 gear stick?
AdrianH
posted on 2/6/09 at 09:35 PM Reply With Quote
I have a spare type 9 gear stick that I want to shorten.
To thread the bar again with the M10 thread I need to separate the two parts of the stick so I can turn down the 11mm bar to 10 mm.
Is it just a pressed in fit to the rubber or is there more to it, how have others done this job?
Adrian
Why do I have to make the tools to finish the job? More time then money.
RichardK
posted on 2/6/09 at 10:28 PM Reply With Quote
Cut it off just above and below the damper assy and welded them together, remember having to grind a taper onto the ends of each bit to create a decent V area to weld.
It's been fine for 1K miles so far.
Rich
Gallery updated 11/01/2011
jollygreengiant
posted on 2/6/09 at 10:31 PM Reply With Quote
Here you go, a quick search and all is revealed.
link to previous posts on subject
blakep82
posted on 2/6/09 at 10:39 PM Reply With Quote
^ ha ha yeah! works perfect too
________________________
AdrianH
posted on 2/6/09 at 11:14 PM Reply With Quote
I was not planning to shorten that much, just so the knob is above the thick section. I thought they may have come apart, but possibly not without damage.
Adrian
Michael
posted on 3/6/09 at 08:23 PM Reply With Quote
I tried everything on my 4 speed one.
The only way it would come apart was to grind away the bell so it would come away from the rubber, then remove the rubber bit.
I have shortened mine to about 3 inches as have built a remote link that is hidden under top trans tunnel tubes.
posted on 3/6/09 at 08:28 PM Reply With Quote
I also took off the rubber bit, then Loctited an extension back onto the stub. I could then make the length of the extension to suit my needs. In my case I used a Momo knob that had 3 screws to fasten it to the shaft - I just drilled 3 dimples to locate the screws and now the thing is nice and secure.
One caution - don't end up with too short a stick, as it makes gear-changing hard work! I added a couple of inches to mine, and it made my life much easier.
Note: it's a good thing that forum members have nice clean minds, what with all this talk of knobs, shafts, members, and so on... oooer!)
AdrianH
posted on 3/6/09 at 09:42 PM Reply With Quote
Thanks all for the replies, I generally only get to view after 10 pm.
Trying to keep it simple I was hoping to remove handle!
Cut down, rethread and put back, only looking to remove approx 3 inches, then realised m10 on 11mm shaft DUH. Because if shape there is no way it will fit into fit into lathe.
I will find a way to do it!
Adrian
bigpig
posted on 4/6/09 at 07:28 AM Reply With Quote
As mentioned earlier cut the top off with an angle grinder and cut the rubber section out then get a rally design quick shift.
They are really nice and for about £15 are not too bad value.
On top of that the road quick shift feels rather nice.
