alistairolsen
posted on 11/6/09 at 01:10 PM |
Anyone tried polyeurathane in a lathe?
Anybody tried machining bushes down in a lathe?
what tools and how well did it work?
MikeCapon
posted on 11/6/09 at 01:13 PM |
Hi. A lot of one off seals etc are machined from polyurethane. I believe the trick is to freeze the bar beforehand. Use a tip with a lot of rake as
for plastics. Never tried it though. Good luck!
tegwin
posted on 11/6/09 at 01:17 PM |
I have seen people cut down bushes using a very sharp knife in a lathe....
.... Using liquid nitrogeon would be the easiest way of making it hard enough to machine properly
www.verticalhorizonsmedia.tv
UncleFista
posted on 11/6/09 at 01:27 PM |
Not in a lathe, no.
I used a drill and a stanley knife
Worked great, I was only shortening them though, I didn't touch the circumference.
![](/galpreviews/cutting2.JPG) ![Description](/gallery/cutting2.JPG) Description
Tony Bond / UncleFista
alistairolsen
posted on 11/6/09 at 01:28 PM |
thats all i want to do, how did you hold them in the drill and whats withthe g clamp?
big_wasa
posted on 11/6/09 at 01:42 PM |
Ive tried it in a lathe and I just chewed them up even after freezing them.
UncleFista
posted on 11/6/09 at 01:46 PM |
I just held a piece of wooden dowel the correct diameter in the chuck and slid the bush over it.
The clamp is to steady the knife against
More pictures here
[Edited on 11/6/09 by UncleFista]
alistairolsen
posted on 11/6/09 at 01:54 PM |
pillar drill, dowel pushed thru bush, tight fit. G clamp around table to steady/lever knife against and a sharp stanley knife?
Looks like it worked well. Apparently the raldes bushes Ive been looking at are 46mm while the brackets I have are 44mm lol Just want to take 1mm off
the shoulders
smart51
posted on 11/6/09 at 02:15 PM |
I know someone who tried. He said don't. It is too rubbery and will either deform under the tool or will rip uneven chunks off. It grinds
well, he says, and suggests a dremel if you think you can do it accurately enough.
andylancaster3000
posted on 11/6/09 at 03:07 PM |
Yes, it's an a*se. Whatever the salesman tells you take it with a pinch of salt.
We gave up and sub-contracted it to my grandfather! He ended up spending 75% of the time making the tooling to hold the stuff for the various cuts. If
you can buy them to fit it might be worth the extra dough!
stevegough
posted on 11/6/09 at 09:21 PM |
Yes, I trimmed all my bushes in a lathe at work - most of them cut very neatly, but the secret is in the shape and sharpness of the tool - I ragged
about 6 of the faces before I got it right - I did all 44 this way.
Make sure you put a crush tube in the centre to cut down on deforming the bush with the chuck.
I can see where the guys are coming from regarding freezing them, though - the stuff is a bit soft to work. Also - use cutting fluid.
Regardz, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
