IanBrace
| posted on 17/6/09 at 05:43 PM |
Spraying 2k
Hi, I'll hopefully soon be ready to put some paint on. I've decided to use 2k. It's years since I've had a go a spraying
anything bigger than the headlight bowls..
Anyone got any tips that you'd care to share with a novice!
A mate has offered to do it for me (for beer vouchers) but i really want to have a go myself.
www.aerialphotography.org.uk
mangogrooveworkshop
| posted on 17/6/09 at 05:48 PM |
A pressure fed mask must be used
[Edited on 17-6-09 by mangogrooveworkshop]
blakep82
| posted on 17/6/09 at 05:53 PM |
air fed masks are the way to go, but have a word with you paint supplier, mine showed me a mask which was not air fed, but is fully certified for 2k
paint.
________________________
CraigJ
| posted on 17/6/09 at 06:24 PM |
I always just use one of these.
http://www.machinemart.co.uk/shop/product/details/midimask-twin-respirator
Sprayed with 2K lots of times and never had an issue with me dropping dead. Just make sure there is also some ventilation.
Also, I don't think 2K is available any more. was phased out last year i think. Most places use water based paint now.
focijohn
| posted on 17/6/09 at 06:50 PM |
i know a place near to me that still supplies 2k..... if you have trouble drop me a u2u
Ok just read your location, maybe not
[Edited on 17/6/09 by focijohn]
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
blakep82
| posted on 17/6/09 at 06:56 PM |
i never knew it was phased out. its been a year since i went to a paint supplier right enough
fazerruss
| posted on 17/6/09 at 07:13 PM |
2k is still available and always will be. As far as i know water based is only used for base coat metalic but you still need a solvent based laquer on
top or the rain will just wash the paint off your car!
"if assholes could fly this place would be an airport"
ashg
| posted on 17/6/09 at 07:21 PM |
you can still buy 2k its celulose that they are trying to fase out.
you will also notice that all shops selling car paint now have to list the voc content of all their products on the reciept so body shops can keep a
record.
[Edited on 17/6/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
| posted on 17/6/09 at 07:23 PM |
Here is an interesting thread on the subject
Phil
flak monkey
| posted on 17/6/09 at 07:42 PM |
This is the problem stuff in 2k paints
http://www.cdc.gov/niosh/topics/isocyanates/
Sera
http://www.motosera.com
austin man
| posted on 17/6/09 at 09:48 PM |
if using 2k make sure the first coat is a guide coat dont try to covet the car allow to go tacky then apply paint evenly.
Its essential that you mix correctly with the activator. If it goes wrong you have to wait ariund 2 weeks before you can overpaint as you will get a
reaction, unlike cellulose which can be flatted and repainted in the same day. You also need to ensure you have a constant pressure at the gun
otherwise you will end up with the orange peel effect.
IanBrace
| posted on 18/6/09 at 02:46 PM |
Thanks guys, I was really after spraying tips rather than not killing myself tips! I'll probably go down that route after I've cocked it
up!
