posted on 22/6/09 at 12:08 PM |
TIG - it's been too long...
I decided that I wanted to weld some stainless steel with my old scratch-start TIG, so I got me some gas and got everything set up and ready to
go...
...it's amazing how much you forget in a couple of years!
First attempt: tungsten disappears with a loud "FUT" because I'd forgotten to turn the gas on.
Second attempt: not too bad, but I dipped the tip into the weld pool a couple of times. Never mind, I gave myself a refresher course in tungsten
grinding.
Third attempt: getting better, but a bit blobby and wandering, because I couldn't see the weld pool properly. Then I realised that I used to
put on the pair of glasses I use for working on the computer, and I was trying to do it with my varifocal glasses - with the welding helmet I was
trying to look at the work using the middle bit of the lens, which is meant for about 10 feet. Doh!
Fourth attempt: the weld looked a lot better once I could see what I was doing...
Now... I need a lot more practice...
omega0684
posted on 22/6/09 at 12:30 PM |
you have to post pictures on a thread like this, its mandatory
posted on 22/6/09 at 12:39 PM |
Oh - OK then... this is one of my later attempts. Nowhere near perfect, but a lot better than the first ones!
stay TIG
It's non-structural, and mostly not visible to the average bystander, so I'll probably leave it as it is (I have tidied it up a bit more
though).
[Edited on 22/6/09 by David Jenkins]
posted on 22/6/09 at 04:00 PM |
Looks pretty neat to me David.
Any advance on what you're up to yet - I have to say it's still got me stumped
yellow melos
posted on 22/6/09 at 04:36 PM |
Post the bad welding as well, makes others feel better and can help them to see where they are going wrong !!
flak monkey
posted on 22/6/09 at 05:35 PM |
I reckon its a wing support
Welding looks fab to me Dave!
Sera
http://www.motosera.com
designer
posted on 22/6/09 at 06:17 PM |
If that is nowhere near perfect!!!!!*****
What is????
posted on 22/6/09 at 06:52 PM |
I know what it is!
posted on 22/6/09 at 06:53 PM |
You're getting warmer...
...positively toasty!
prawnabie
posted on 22/6/09 at 06:57 PM |
Its the outer wing support that will run on a bearing secured to the outside face of the wheel?
posted on 22/6/09 at 07:17 PM |
No bearing...
...and I'm not saying any more until it's finished and proved to be road-worthy!
(probably get its first public outing at Paul & Gaz's BBQ next Sunday, weather permitting).
posted on 25/6/09 at 09:29 AM |
Are you planning to mount your headlights on the wings and have them swivel with the steering...?
posted on 25/6/09 at 10:05 AM |
No - I'm just fed up with having to reweld my stays every thousand miles...
...and it appears that my new setup works - I'll shout about it when I've finished, but I can say that my wings now have zero flapitude
when driving over bumpy roads.
