Author: Subject: M19 tap wanted..
posted on 24/6/09 at 12:26 PM Reply With Quote
M19 tap wanted..
Where can I get an M19 x 0.8 or imperial equivalent?
Want to to tap a bit of alli for a starter switch.
Does such a size exist? Where from?
Mr Whippy
posted on 24/6/09 at 12:52 PM Reply With Quote
most starter switches I've seen have their own nut
only M19's I can see are for 1 & 1.5, not 0.8
sure you have measured the thread correctly?
posted on 24/6/09 at 01:02 PM Reply With Quote
3/4 UNF probably..... but 16 tpi = 1.58 mm pitch
[Edited on 24/6/09 by 02GF74]
pewe
posted on 24/6/09 at 01:17 PM Reply With Quote
Try www.tracytools.com - helpful and quick on mail order.
HTH.
Cheers, Pewe
posted on 24/6/09 at 01:38 PM Reply With Quote
Yep, measured it at either M19X0.8 or 3/4"-40tpi.
I'll have a go at putting a recess in and bonding the nut in the top, that should do it.
Ta,
