Author: Subject: 3/8 NPT nut
Benzine
posted on 29/6/09 at 11:31 AM Reply With Quote
3/8 NPT nut
I've got sensors for my megasquirt unit, I'm after a couple of nuts that I can weld in place for the sensors to sit in. The thread I need is 3/8 NPT (American National Pipe Thread) :/
Firstly why is it called 3/8 (which is around 10mm isn't it?) when the thread I need is closer to 17mm? secondly, where can I get a couple of these nuts?
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make it moral.
flak monkey
posted on 29/6/09 at 11:47 AM Reply With Quote
Pipe thread sizes refer to the bore of the pipe on which they are designed to be used.
Sure someone can knock you some threaded bosses up.
Sera
http://www.motosera.com
blakep82
posted on 29/6/09 at 11:49 AM Reply With Quote
had a similar question the other day, the 3/8" refers to the i.d of the pipe its supposed to fit with.
sorry, thats a terrible description. i'll try again later if someone else doesn't get there first...
________________________
owelly
posted on 29/6/09 at 11:54 AM Reply With Quote
Use a 3/8" NPT tee piece and cut it up. You'll have three bosses then!
http://www.ppcmag.co.uk
minitici
posted on 29/6/09 at 12:24 PM Reply With Quote
3/8" NPT is a tapered thread.
You really need to use a 3/8" NPT tap to tap a weld in boss.
Benzine
posted on 29/6/09 at 03:52 PM Reply With Quote
where can one get such a tee piece? ^_^
owelly
posted on 29/6/09 at 05:29 PM Reply With Quote
U2U me your address and I'll send you one.
And for info, the female part of a tapered thread isn't tapered. The male part is.
flak monkey
posted on 29/6/09 at 06:27 PM Reply With Quote
I think that is incorrect. Both the male and female threads are tapered.
Certainly the taps I have are clearly tapered, and not just the lead in!
Sera
Benzine
posted on 29/6/09 at 06:40 PM Reply With Quote
It looks a bit tapered but it's hard to tell
[Edited on 29/6/09 by Benzine]
flak monkey
posted on 29/6/09 at 06:44 PM Reply With Quote
If thats for MS and the std vauxhall senders then they are indeed 3/8NPT
Sera
flak monkey
posted on 3/7/09 at 10:44 AM Reply With Quote
I can make you some if you still need them.
Let me know what material etc you want them made from and I will see what I can do.
Sera
