posted on 19/8/09 at 07:24 AM |
joining small metal rod?
Need to lengthen my choke cable, solid rod in metal spiral tube.
Also needs to be disassemblable.
Thinking of attempting to drill a short length of round brass bar* with two screw in side to hold the rod or elase make 2 clamping plates.
Any other ideas?
* easier said than done without a lathe.
(I will be getting new choke cable just don't have time before the weekend).
r1_pete
| posted on 19/8/09 at 07:32 AM |
Could you use the metal bit from a chocolate block wire connector?? They come in various sizes, should find one suitable. Or does it need to slide
inside the spiral?
Mr Whippy
| posted on 19/8/09 at 07:36 AM |
don't you do r/c models...
linky
| posted on 19/8/09 at 07:40 AM |
yeah, coupling sleeve is what I have in mind but £ 3
I know, not a lot but that would be better off going towards new choke cable.
Good call, forgot that I saw Maplins selling them.
Re: previous post - the outer has a stop at first carb, the join needs to be in between the 2 carbs, loads of room and just hold the 2 pieces of rod
together.
At a push I guess I can wrap wire and solder, it should only be on for a week or so.
| posted on 20/8/09 at 08:07 PM |
and that is what I've done. a short length of gardening wire to join up the second carb, and it works too.!
[Edited on 20/8/09 by 02GF74]
