Author: Subject: Sticking alloy together?
tomgregory2000
posted on 22/8/09 at 05:43 PM Reply With Quote
Is it possible to weld cast alloy (say an inlet manifold) to alloy tube and it stick?
How easy is it?
Will i just end up with my feet covered in molten alloy?
Tommy
posted on 22/8/09 at 06:01 PM Reply With Quote
You might be better off friction stick welding it (Technoweld type stuff). Welding alloy isn't so easy even if it's pretty pure stuff....
big-vee-twin
posted on 22/8/09 at 06:05 PM Reply With Quote
Alluminium Welding
Try looking at Durafix
www.durafix.co.uk
mark chandler
posted on 22/8/09 at 07:22 PM Reply With Quote
It should TIG up without a problem, the cast is probally very poor grade so just check its not porus afterwards.
There used to be plenty of modified manifolds for 3litre fords and V8 rovers where they just cut off the weber/SU mountings and welded on a plate to accept a holly.
Regards Mark
irvined
posted on 22/8/09 at 07:50 PM Reply With Quote
Should be pretty easy if you use something like durafix or alutight/al75.
Mig welding alloy is possible but its tricky, if you dont already have a setup ready for welding alloy, the duraweld sticks are well worth a go.
http://irvined.blogspot.com
trikerneil
posted on 23/8/09 at 05:32 AM Reply With Quote
You could try Bruce at BB Customs on the Ferndown industrial estate if you want it TIG-ing.
01202 890680
HTH
Neil
ACE Cafe - Just say No.
