speedyxjs
posted on 11/9/09 at 07:36 AM |
Anyone got one of these?
Impact
wrench
Air compressor is out of the question due to the cost and i was wondering if anyone has used one of these?
Hopefully it will be powerful enough to undo the crank pulley bolt!
posted on 11/9/09 at 07:55 AM |
Looks very similar to the 24v Clarke impact wrench, and that struggles to undo tight wheel nuts and won't even look at a tight crank pulley bolt
(tried it on my mums Corsa).
The mains powered Clarke one isn't too bad, but you really need a decent brand name gun to get the best performance. Unfortunately that means
l0rd
posted on 11/9/09 at 08:09 AM |
Me being a noob i have to ask.
How on earth one of these can be better than a 25" long breakers bar?
thunderace
posted on 11/9/09 at 08:17 AM |
i have a roybi one and cant even remove wheel nuts you can get a 12v one that plugs into the fag socket in a car that has real power i used one to
strip a full car in a scrap yard with no problems.
it looks like this one
Item number: 380157126404
here is a great one Max. torque 450Nm
New Clarke CEW1000 Electric Impact Wrench 240v £49.99
Item number: 150371511296
* 1000 Watt, 230V motor
* Max. torque 450Nm
* No load speed 2200rpm
* No load impact rate 3400ipm
* Drives bolts up to a max size of M12
* Bit holder size ½" square drive
* Includes socket sizes 17, 19, 21 & 22mm and carry case
here is one for £10 that will kick a cordless ones ass
Item number: 320422245848
(have your engine running when you use it it gives you arond 30% more power)
[Edited on 11/9/09 by thunderace]
I guess you've never used one! They apply very high peak torque in short bursts which is effective for loosening tight fasteners. The main
advantage though is that with a breaker bar you need to arrange for the part you are working on to resist the constant torque you are providing, e.g.
locking crank on an engine. Since the torque is only apllied for a fraction of a second with an impact wrench you can just rely on the inertia of the
part to resist it.
speedyxjs
posted on 11/9/09 at 08:34 AM |
Thanks for the replys. I saw the clarke one but wasnt sure if it would be any good.
Looks like i may have to fork out a bit more (its a tough nut!)
ETA - Dont really fancy using the cig lighter socket as the locost doesnt have one
[Edited on 11-9-09 by speedyxjs]
deezee
posted on 11/9/09 at 08:52 AM |
We have a 110v impact gun at work. We use it for removing seized nuts off furnaces, which is a considerable problem with the hot environment.
However a 24" breaker bar and a 5ft length of scaffold is twice a quick and considerably quieter. Oh and impact guns should use strengthen
sockets, which just add more and more cost.
posted on 11/9/09 at 08:56 AM |
part to resist it.
he's right you know
damn handy undoing the nut on an alternator; couldn't undo with a ratchet due to it turning and no means to grip without damage.
speedyxjs
posted on 11/9/09 at 09:16 AM |
Tried that on the pulley yesterday but it wouldnt budge
Mr Whippy
posted on 11/9/09 at 09:39 AM |
I have a 12v battery one that looks like sh%t that I got as a present. Sounds scary with lots of whirring and banging but so far has removed
everything thrown at it, including mental landy wheel nuts & the beetles hub rear hub nuts
looks similar to this -
[Edited on 11/9/09 by Mr Whippy]
iank
posted on 11/9/09 at 09:55 AM |
You're using a 5ft scaffold cheater bar without strengthened sockets?
[Edited on 11/9/09 by iank]
Anonymous
Mr Whippy
posted on 11/9/09 at 10:18 AM |
If their well made normal sockets then you shouldn't need to bother with hardened ones when using even an extended breaker bar. As although the
impact wrench will shatter normal sockets and produce fragments, a breaker bar will only split them open harmlessly (unless you drop the bar on your
foot).
However you are much more likely to damage other components using a breaker bar instead of an impact wrench and I’d not like to use a bar on an engine
tbh.
hughpinder
posted on 11/9/09 at 02:21 PM |
Just managed to get the crank pulley bolt off my honda - 3/4 inch impact driver struggled (600 ftlb!)
Regards
Hugh
ashg
posted on 11/9/09 at 03:27 PM |
i went mad and got a top of the range bosch one. havent found anything it wont do yet. something like 300-350nm of torque from memory.
anything over 200nm should be fine really. the tightest thing on a sierra are the rear hub nuts and they are only done up to 180odd nm
[Edited on 11/9/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 11/9/09 at 03:34 PM |
The problem is the difference between the claimed torque and reality in the case of cheap Chinese tools. They are not exactly averse to inflating the
specifications of equipment by rather large margins!
l0rd
posted on 11/9/09 at 04:23 PM |
Sorry about the noob question earlier, but i tend to strip the threads from the bolts using sockets. I am sure, with a breakers bar you can remove
prety much enything
posted on 11/9/09 at 06:04 PM |
I am sure, with a breakers bar you can remove prety much enything
Yes you can, but it's not always a convenient way to do things. If you are under a car on axle stands for instance, trying to wield a large
breaker bar can be very difficult, and as other have suggested, pulleys on alternators present a challenge since it's very difficult to stop the
rotor turning without damaging things like the fan.
posted on 11/9/09 at 06:50 PM |
my air wrench is useless. Its a clark one, and i only use it as a nut spinner. I hear a lot of people say the electric ones are good so i may get one
one day.
turbodisplay
posted on 11/9/09 at 09:46 PM |
2nd the clarke are poor. couldn`t undo a 10mm 12.9 caliper bolt, used a air wrench manually and it undid it.
Seem to behave better oiled though.
Darren
iank
posted on 12/9/09 at 08:35 AM |
foot).
Yeah, my point was more that I can't imagine a regular socket NOT splitting if you actually need the 5ft cheater.
Anonymous
NS Dev
posted on 18/9/09 at 08:50 PM |
one day.
ditto!!
A mate who's a truck mechanic is donating me his old chicago pneumatic jobbie, its at least 4 times the power of the clarke piece of poo
Benzine
posted on 18/9/09 at 08:58 PM |
I've seen a snap-on £400 electric one used on my crank nut, so impressive. Breaker bar wasn't an option due to space, air impact wrench
was useless, snap on version got it off instantly.
Another time when I had to get off a crank nut I hired a feck off electric impact wrench from hire station for the day, that worked! It was 3 phase
but they threw in an inverter/adapter too so I could use it
The same crank nut I managed to get off once with a breaker bar when the engine was out of the car. It meant strapping the engine against a huge beam
and using all my strenght, was a right pain. I'll definately invest in a flip hot electric one at some point
[Edited on 18/9/09 by Benzine]
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
atomic
posted on 20/9/09 at 01:57 PM |
For cordless impact wrenches it just depends on what you want it for really and your budget. I truly believe that you are paying a very high premium
for the Snap-On name of electric impact wrenches, there are makes out there that are just as high quality if not better and cost less, from the like
of Makita & Mac etc
I use a Makita BTW215 at the track for changing wheels etc but also have it's big brother the BTW450 when more torque is required. As they both
use the same battery's and charger I bought a discount pack one with 2xbatteries and a charger at a trade show (though you can find these online
without much problem) and then bough the other one naked, so just the wrench alone - which same me quite a bit.
I noticed one day while talking with Seb Loeb and looking in his car that they also carry a BTW251 for changing wheels on the stages so that should
say something.
Air tools are really the same deal, you pay a premium for Snap-On when others like Mac, Chicago Pneumatic & Ingersoll Rand are just as good,
though I have to confess I do own a Snap-On air impact wrench and ratchet, though I have a mac ratchet also that was 1/2 the price of the Snap-On and
it's easily as good.
[Edited on 20/9/09 by atomic]
