pdm
posted on 15/10/09 at 08:50 AM |
Clarke Heavy Duty stand
Morning all,
Looking at an engine stand on ebay at them moment - it's a clarke heavy duty stand.
My question is what bolts/mounting arms would it have come with when new ?
If it hasn't got them all can you get spares or should I wait for the next one ?
thanks in advance
Paul
mookaloid
posted on 15/10/09 at 08:59 AM |
I have the lighter clarke one, it came with 4 arms but no bolts to mount the engine with
Mark
Myke 2463
posted on 15/10/09 at 09:00 AM |
Dont forget vat free day soon @Machine Mart. start @ 34.99 exc vat with gnt.
pdm
posted on 15/10/09 at 10:14 AM |
Ok thanks.
Daddylonglegs
posted on 15/10/09 at 10:36 AM |
Ditto on the Clarke light-weight one. I have one too and just used bolts I will use to mount the engine/gearbox eventually. Mine didn't come
with any either.
HTH
JB
BTW, made a good basis for my 'rotisserrie' when building the chassis
trextr7monkey
posted on 15/10/09 at 11:02 AM |
Ours came with some tensile bolts but if they are too short we have used lengths of threaded bar and big washers to accomodate engines with clutch
still attached
posted on 15/10/09 at 11:17 AM |
yeah, but how many different bolts would it need to accomodate all possible engines?
don't you use the same ones that bolt to the gearbox?
jabbahutt
posted on 15/10/09 at 12:35 PM |
heavy duty stand comes with 4 arms and bolts to attach the arms to the stand.
No bolts are included to attach to the engine. I just picked up some decent length ones with washers and nylocks as I attached the engine at the rear
using the bell housing attachment lugs.
Hope that helps.
stevegough
posted on 16/10/09 at 09:29 PM |
I don't think your question has been answered fully - you asked about bolts and arms - the mounting bolts don't come with any new
stand - you usually need the right length of high tensile - [coded 8.8] 12mm bolts (as I remember) but the length and diameter will depend on the make
of engine.
However, if the one you are looking at is missing the arms, that is a bit more of a problem - I don't think you would be able to buy them
seperately - and if you make them, ensure they are strong enough - they have to support plenty of weight.
In short - beware buying incomplete second - hand tools - especially when they are only £35 new!
Hope this answers your question,
Regards, Steve.
Ps - here's a photo showing two of the arms on mine.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
