pdm
| posted on 28/10/09 at 10:13 PM |
Measuring clearances
Evening all,
Almost finished stripping down my practice engine now so I will be moving onto measuring bores/pistons etc etc soon and have a few questions if I
may.
As before I'm a novice here so although these maybe simple questions they are genuinely asked.
1) Piston ring gap - as I understand it you fit the rings one at a time and then slide them into the cylinder with a compressor. I envisaged then
putting a feeler gauge in to check the gap not realising that ring gap is tiny - how is this done ?
2) Similarly - how do you measure ring to bore clearance without bending the feeler gauge ?
3) Although I don't have any I would like to get a set of those inner micrometer bore gauge things - but how do you get those
"tight" enough to measure bore diameter without scratching the bore when you remove them ?
4) Do you do all the above with or without oiling the surfaces being measured ?
5) When measuring any diameter - is there an easy method for ensuring you are at the widest part ?
6) With a feeler gauge is it meant to drag and if so by how much ?
So hopefully not too many questions there for you all.
Thanks in advance.
Paul
daviep
| posted on 28/10/09 at 10:47 PM |
1) Ring gap: Put the ring in to a worn part of the bore and measure the gap between the ends of the ring. The rings are not fitted to the piston to do
this.
2) Ring to bore clearance: Not something I've ever heard being measured, there should be no clearance between the ring and bore.
3) Depends what you measure with. Dial bore gauge is sprung loaded as are telescopic plunger guages. Internal calipers should just be a nice drag not
tight enough to score.
4) Without
5) Measure at various points, you are looking for the smallest measurement i.e that you are dead square across the bore.
6) Yes it should drag, but not too much.
Any other questions just ask.
Davie
[Edited on 28/10/09 by daviep]
pdm
| posted on 29/10/09 at 08:25 AM |
Cheers Davie - I'll see how I get on.
Thanks for your help.
richardlee237
| posted on 29/10/09 at 09:34 AM |
You should also be measuring the ring axial clearance. i.e the gap between the side of the ring and the side of the groove.
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
pdm
| posted on 29/10/09 at 10:07 AM |
Hi Richard
Do you mean fitting the ring and then measuring the gap between the top (horizontal) face of the ring and the ring landing and then the bottom face
and ring landing. Does the ring "rest" on its bottom face and therefore have zero clearance ? Do you have to measure top and bottom at
the same time - ie. if I put a feeler gauge in the top am I not pushing the ring down the land ?
Or do you mean the diameter of the ring landing and the inner diameter of the ring itself - as far as I can see I'd have to do this without
fitting ring so how do I measure inner diameter without expanding the ring ?
thanks
Paul
bmseven
| posted on 29/10/09 at 10:15 AM |
Good question and Good Answers
Is it not worth making this a sticky post?
BMW 7 Resource
Bures Pit anyone?
