liam.mccaffrey
| posted on 3/12/09 at 12:04 AM |
Vacuum Pump
anyone have any advice about obtaining a vacuum pump on the cheap. Enough to continually pull maybe 8 PSI.
Read somewhere about 10 years ago about modifying a compressor pump. Can't remember a lot about it though.
Any ideas?
Build Blog
Build Photo Album
Mr G
| posted on 3/12/09 at 12:30 AM |
Ann Summers?
liam.mccaffrey
| posted on 3/12/09 at 12:32 AM |
tried there, i can't fit the 'thing' I want to vacuum in the chamber
Build Blog
Build Photo Album
dave r
| posted on 3/12/09 at 07:00 AM |
fridge pump will pull a vac
dont know if it would be big enough for what you need
speedyxjs
| posted on 3/12/09 at 07:16 AM |
Connect a big enough chamber to an inlet manifold?
Danozeman
| posted on 3/12/09 at 07:30 AM |
LDV's have a vac pump for the brakes and some older peugeots driven off a v belt. Not sure of the pressure they pull.
Obviously wont work if you need an in house one though.
Dan
Mr Whippy
| posted on 3/12/09 at 07:40 AM |
I read on the web that using a car engine was a very effective and many times more powerful source than a vacuum cleaner etc to do vac forming of
plastic. Yet to try this myself but it seems very good
bigbravedave
| posted on 3/12/09 at 08:11 AM |
golf mk3 central locking pump cheap on the bay
907
| posted on 3/12/09 at 08:16 AM |
I've got this for sale. £70 collected.
It was used to test pressure vessels.
When I was made redundant and the company closed it found it's way into my garage.
( by 8psi I take it you mean half a vacuum )
Paul G
Staple balls
| posted on 3/12/09 at 08:21 AM |
Is that a Vac, or an Uum?
Hammerhead
| posted on 3/12/09 at 09:50 AM |
it depends what you want to vac form. I had good results with an american made 'shop vac' pulled a 500mm diametre half dome to a depth of
250mm on 5mm thick acrylic.
Shop vacs are about £40.
I'm sure the best solution is 907s pump though.
liam.mccaffrey
| posted on 3/12/09 at 10:06 AM |
just been given one from a friend almost exactly like 907's
thanks chaps
Build Blog
Build Photo Album
Mr Whippy
| posted on 3/12/09 at 10:24 AM |
yeah in the past I've done some canopies for my r/c planes on a DIY box machine thing connected the Dyson, biggest is about 30cm long and 10cm
deep though its just 0.8mm thick plastic. Definitely one of the most fun ways of making things
Hammerhead
| posted on 3/12/09 at 11:07 AM |
its a great thing to do. the problem with a dyson is they have a safety valve for in case any body parts get inadvertantly sucked in! i'm sure
its fine for 0.8mm though.
dhutch
| posted on 3/12/09 at 12:41 PM |
One word. Gaffa tape...
| posted on 3/12/09 at 01:06 PM |
You have to use gaffer tape to avoid getting sucked into the Dyson I just keep my clothes on while I clean up
P.S. one word Gaffa two words = Gaffa + tape
[Edited on 3/12/09 by Peteff]
subevo
| posted on 31/12/09 at 06:49 PM |
ive got a" mes dea" do a search. electric vacuum pump
cost around £230.(toyota mr2 s mk3s have them fitted due to mid engine layout ).its designed for electric vehicles.i built a daewoo matiz electric
car.this pump is ultra quiet and has solid state vacuum switch.so nothing to go wrong.works a treat.have a look on www.diyelectriccar.com for info on
cheap vacuum pumps.there is one called the thomas a lot of people use but its noisy and you have to bugger about with vacuum switches.mines costs more
but its fit and forget.not so the others.
