liam.mccaffrey
posted on 3/12/09 at 10:07 AM |
Badge Infill Enameling(sp?)
Anyone know whats envolved on a DIY basis. Can't be that hard can it?
[Edited on 3/12/09 by liam.mccaffrey]
Build Blog
Build Photo Album
Mr Whippy
posted on 3/12/09 at 10:11 AM |
What about the resin used in DIY stain glass, from what I’ve seen that is very easy to do
I’ve actually been thinking of possibly doing this as a job (stained glass that is)
Suppose a badge is just a simple sand casting, just make the mould from balsa and melt some aluminium?
I have some aluminium from an inlet manifold that has melted in an a car fire and poured onto the road, amazing detail of the road surface, I kept it
as the metal looks very easy to use for model parts casting.
[Edited on 3/12/09 by Mr Whippy]
austin man
posted on 3/12/09 at 11:05 AM |
I made a badge for my A35 using casting resin, made the original cast from latex and plaster of paris. The trouble I has was that it needed the type
of paint used on mirrors on the back and I couldn't get hold of any. Got the resin from a craft shop
owelly
posted on 3/12/09 at 12:40 PM |
We used to use the powedered/shaped enamel stuff at school. We made whatever shape we wanted out of copper and then put the powder on top and then
made a design out of the shapes (usually little sticks to write your name) and then you heated it up in an oven or gave it a blast with the oxy
gear...... Instant shiney things...I still have the keyring somewhere. I has a blue cock on it...
http://www.ppcmag.co.uk
trextr7monkey
posted on 3/12/09 at 02:00 PM |
Hi couple of points in school we now use pewter for casting- could be useful if making own moulds a snot muchheat m needed tomelt it - ladle and
bunsen burner.
Enamelling on copper still in use - have a small kiln here which hardly sees any use so we might be able to help with the odd prototype.
The other thing worthh thinking about is dye sublimation which allows you to print a digital image of a badge ( could be a distorted versionof some
one else's that you "admire" onto plastic (flat ) then with a suitable matching former you can vac form it (3d) then trim it
out!
Cunning or what?
atb
Mike
Angel Acevedo
posted on 4/12/09 at 12:05 PM |
Aluminum Metalcasting.
There`s a Webring with Plenty of info about smelting scrap Aluminum, you could use wax lost method on Plaster of Paris, provided you kiln dry te mold
well before pouring.
I hav done it with a couple of cans of Baby milk as air chamber and furnace, and a can of beans as a laddle.
Dangerous? yes, Scary? yes, Satisfactory? Yes.
I have a bunch of stuff at my garage to make a more permanent safer outfit to do maybe 5-6 lbs castings.
Thats on the "back Burner" for now due to commitments with my locost projec.
PS: Rerading the thread, this one may be a little bit OT, sorry...
