pdm
| posted on 11/12/09 at 09:51 AM |
Mounting zetec to a stand
Morning everyone,
Finally onto rebuilding my engine which is a zetec silvertop and I've got a couple of questions about mouting it to my engine stand if I may.
I only really have 4 possible bolt holes all of which appear to be 10mm - that is the cylinder head bolts fit in them (which are T50 I think from
memory). Two of the holes are threaded and two are straight through (I think they are locating lugs for the bellhousing). The cylinder head bolts
when screwed as far as they will go into the threaded holes stick out to far past the stand mounting to make them useable.
So my only fixing option bolt wise seems to be M10 x 80mm, two into the threaded holes with washers, two through the non threaded holes with
washers/nuts.
My questions are:
1) Does this seem ok ?
2) Could I use the cylinder heads bolts in the non threaded hole and use M10 nuts with them ?
3) M10 to me doesn't seem a lot to be holding an entire engine on with - is there a risk of stripping the threads or anything else I should be
looking out for ?
thanks
Paul
turbodisplay
| posted on 11/12/09 at 09:56 AM |
Those locating lugs are threaded.
Darren
Bumble
| posted on 11/12/09 at 10:04 AM |
It's how I'm doing it with same engine. I used 4 off M10 x 100 bolts to fit the engine to my stand. 2 into the threaded holes and two
straight thru with washers and nuts either side. Been mounted for several weeks and pushed all around the garage with no issues. Be careful when
rotating the engine though!! You can just see 1 of the botls in the attached pic. HTH.
Matt
pdm
| posted on 11/12/09 at 10:15 AM |
Great thanks to both of you.
Dusty
| posted on 11/12/09 at 10:38 AM |
Above works fine for me too.
Danozeman
| posted on 11/12/09 at 11:44 AM |
I used threaded rod when i did mine,.
Dan
r1_pete
| posted on 11/12/09 at 06:24 PM |
Me too, it was on the stand for months with no issues....
| posted on 11/12/09 at 08:17 PM |
Dunno if you can see it but i used the offside block mountings as I wanted to fettel the ali housing.
pdm
| posted on 11/12/09 at 09:14 PM |
Great thanks everyone
Never thought of mounting it "sideways" coozer !!
