splitrivet
posted on 13/12/09 at 01:21 PM |
Welder experts
Am I right in thinking that one of these
http://cgi.ebay.co.uk/JG-50-A-Air-Plasma-Cutter-torch-50A-12-feet_W0QQitemZ350273313192QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item518dea99a8
providing the connections are OK could be fitted to my DC Tig welder and turn it into a plasma cutter or am I just being dillutional.
BOB
posted on 13/12/09 at 01:32 PM |
Don't plasma cutters use compressed air as well??
MakeEverything
posted on 13/12/09 at 01:33 PM |
I dont think theres any reason why it wouldnt work on an AC TIG as well.
Might consider one for myself at that price!!
Kindest Regards,
Richard.
MakeEverything
posted on 13/12/09 at 01:34 PM |
Or oxygen mix, but its only purpose is to "Blow" away the molten slag.
Kindest Regards,
Richard.
splitrivet
posted on 13/12/09 at 01:44 PM |
Combined with a compressor of course.
Bob
wilkingj
posted on 13/12/09 at 01:49 PM |
Plasma cutters use compressed air, not O2 or any other gas.
I think you cant use a plasma torch on a std TIG. I think the voltage is different for a TIG to a plasma Cutter.
I am not exactly sure, but I think the plasma cutter uses a mugh higher voltage than a TIG set.
Unless you have a special Dual Mode set, it wont work on a Std TIG machine.
Best Regards
Geoff
http://www.v8viento.co.uk
flak monkey
Welders are high current, low voltage (30v open circuit). Plasma cutters are low current high voltages (10,000v+) so no, it wont work.
Sera
http://www.motosera.com
mark chandler
posted on 13/12/09 at 02:06 PM |
dillutional, sorry
daviep
posted on 13/12/09 at 02:45 PM |
That's not really an accurate description.
The high voltage DC ionises the gas so that it forms an extremely high temperature "plasma stream", it is the plasma stream which cuts the
workpiece. It does also carry the melted material out of the cut.
MakeEverything
posted on 13/12/09 at 04:57 PM |
Kindest Regards,
Richard.
splitrivet
posted on 13/12/09 at 08:06 PM |
Well thats another bag of chips well and truly pee'd on then.
Bob
posted on 13/12/09 at 09:06 PM |
They only use that much voltage to start the arc, just like a TIG with HF start. Voltage when cutting is much lower (~140v), though still higher than
a TIG.
flak monkey
posted on 13/12/09 at 09:10 PM |
I thought they maintained a high voltage to create the plasma stream?
Or is it a case of once the plasma is flowing it doesnt need a big voltage differential to maintain it?
Sera
posted on 13/12/09 at 09:57 PM |
think it will be like a lightning machine, huge volts to create an arc but once the air is ionised the resistance will be much lower.
posted on 13/12/09 at 10:14 PM |
It's just like a TIG arc, once the arc is struck the resistance drops significantly so lowers the voltage required to maintain the arc.
posted on 13/12/09 at 11:50 PM |
quote: Originally posted by mark chandler
dillutional, sorry
Delusional ? Sorry the tig won't power a plasma arc or there would be a lot more tigs being sold as dual purpose machines.
flak monkey
posted on 14/12/09 at 08:00 AM |
Now I know Thanks for that
[Edited on 14/12/09 by flak monkey]
Sera
