Numb nuts
| posted on 27/12/09 at 04:44 PM |
Porting aluminium head/inlet manifold
What are you good people using to port ali heads etc.
The usual stone grinding wheels e just clog.
snakebelly
| posted on 27/12/09 at 04:54 PM |
high speed die grinder bit, you can get them from any good engineering supply place, only triuble is they need to run at a high speed so you really
need an air powered die grinder
Jon Ison
You need a good quality "burr" or a set off, will go off and google a link....
Jon Ison
| posted on 27/12/09 at 04:57 PM |
Something like this
but do a bit of homework on quality 1st.
| posted on 27/12/09 at 05:00 PM |
Should never use standard grinding wheels on alloy! The best tool for this is a
tungsten carbide burr.
[Edited on 27/12/09 by MikeRJ]
Numb nuts
| posted on 27/12/09 at 05:03 PM |
Thanks for that...time to do a bit of shopping
snakebelly
posted on 27/12/09 at 06:05 PM |
also known as die grinder bit...
| posted on 27/12/09 at 06:22 PM |
I have a 110 v die grinder that is so much better to use than an air powered tool . Tungsten bit is what you need
| posted on 27/12/09 at 07:18 PM |
I use one
THESE in the drill, works a treat on ali and steel.
iank
| posted on 27/12/09 at 07:26 PM |
Get one with a long nose like these
http://www.tooled-up.com/Product.asp?PID=4728&Referrer=froogle
http://www.tool-net.co.uk/p-325670/makita-gd0800c-240v-die-grinder.html
[Edited on 27/12/09 by iank]
Anonymous
| posted on 27/12/09 at 07:49 PM |
Very much like the one I have but I only paid £20 off the bay , already had the transformer
will121
| posted on 27/12/09 at 10:53 PM |
just ported my zetec head, £8 tongsten round ended rotary burr, £10 flexi-drive (keep it greased though) and standard drill, plus a couple of 20/25mm
flap wheels £4 done the trick nicely
[Edited on 27/12/09 by will121]
thepest
| posted on 28/12/09 at 07:41 AM |
And I found gear oil to be a great lubricant when porting aluminum.
SPYDER
| posted on 28/12/09 at 02:16 PM |
WD40 is better.
Mark Allanson
| posted on 29/12/09 at 12:36 PM |
Parafin is recommended
Angel Acevedo
| posted on 30/12/09 at 02:45 AM |
Grinding Aluminium
Somewhere in Internet I read that you could use regular metal grinding discs/stones for aluminiumm if you apply them to a block of beeswax, and keep
doing it regularly.
http://www.practicalmachinist.com/vb/sitemap/index.php/index.php/grinding-wheel-selection-t157557.html
***Disclaimer: Do the above at your own risk***
One thing I know for sure, is that you can cut longer with the Tungsten Carbide tips if you apply regular chalk on the grooves as this prevents
cuttings from piling up.
My $ 0.02 MXP
