speed8
| posted on 28/1/10 at 08:30 AM |
Can you weld aluminium bronze to mild steel?
As per the title.
I had a part made up but they forgot the fact the I asked for mild steel. I've asked them to remake it for me but it made me wonder if aluminium
bronze would actually be ok.
I know welding aluminium to mild steel can be done but not normal practice but is aluminium bronze any easier to work with?
| posted on 28/1/10 at 08:47 AM |
In my model-making days aluminium bronze was considered a total PITA - it machined beautifully but wouldn't take silver-solder.
smart51
| posted on 28/1/10 at 11:25 AM |
Wikipedia says you can MIG weld aluminium bronze with aluminium bronze wire and Argon gas. That's to iteslf, I guess. Mind you, if you can
braze to steel with copper or brass as a filler, I guess you can braze CuAl to steel too.
RAYLEE29
| posted on 28/1/10 at 02:34 PM |
hi, Ali bronze doesnt like to be heated it goes all funny shaped etc
you may be able to braze with the correct flux but I feel sure you will suffer from distortion
prob best to get it remade in steel if it needs to be welded
Ray
speed8
| posted on 28/1/10 at 02:42 PM |
Yeah, I figured it would need to be redone. It's for an adaptor to go from my Sierra column to a Lifeline QR spigot so I don't want to
take any chances on suspect materials. Still, nice bit of work for a freebie, shame it's the wrong material.
Confused but excited.
| posted on 28/1/10 at 03:10 PM |
You could get it done by Electron Beam Welding if you really had to but would costo mucho diniro.
| posted on 28/1/10 at 03:52 PM |
quote: Originally posted by smart51 Mind you, if you can braze to steel with copper or brass as a filler, I guess you can braze CuAl to steel
too.
The aluminium will melt before the braze is liquid. What is the process for aluminium to steel ? It's something I've never heard of
although I don't think I need to, really
speed8
| posted on 28/1/10 at 04:33 PM |
too.
It's been suggested that explosive welding would do Al to steel but on an industrial scale (and costs) rather than hobby scale. There was
another method mentioned but I can't remember what it was.
MakeEverything
| posted on 28/1/10 at 05:43 PM |
too.
^^ Ditto.
I dont understand why Ali would need to be welded to steel in the first place???? Surely with one being ferrous and the other non-ferrous, they
wouldnt mix properly?
Kindest Regards,
Richard.
