eddie99
| posted on 29/1/10 at 09:10 AM |
Curved Router Tool
Hi Guys,
Im after a curved router tool 20+mm radius to curve the bottom edge mould for my dashboard.
Does anyone know where i can find one? or do they even exist? B&Q only had 10mm max.
Regards
Ed
Richard Quinn
| posted on 29/1/10 at 09:22 AM |
Yes, they exist but they aren't cheap at somewhere around £40 to £60!
eddie99
| posted on 29/1/10 at 09:27 AM |
Because of this price, do you reckon some hire companies might hire them out for less? even if its with a router?
Ed
Richard Quinn
| posted on 29/1/10 at 09:33 AM |
Possibly. Worth giving HSS or the likes a quick call. I did look into getting one but then decided it would be cheaper to buy a dash already done.
big-vee-twin
| posted on 29/1/10 at 09:44 AM |
One here but yes they are expensive link
http://www.triangleltd.com
kendo
| posted on 29/1/10 at 09:47 AM |
Another way which might work is if you attached semi circular beading to the bottom edge.
| posted on 29/1/10 at 09:59 AM |
Or go over it twice with the 10mm Seriously, why does it need to be 20mm, you only need to take the sharp corner off and a 10mm bit is about £7 or
available in cheap sets. Set the router depth so it doesn't leave a step.
bodger
| posted on 29/1/10 at 10:01 AM |
I got some 21mm quarter profile beading from B&Q for about £4 for 2m. You won't get a router bit for that!
r1_pete
| posted on 29/1/10 at 10:04 AM |
I reground a router bit to about 20mm, to radus the corners of a guitar amp cabinet.
You can have it if you want, just a std. 1/4 inch shank. U2U me your address and its yours.
splitrivet
| posted on 29/1/10 at 10:17 AM |
I your padding the dash with foam ie camping mat and vinyl a 10mm roundover and the covering will be near as damnit to 20mm.
Bob
eddie99
| posted on 29/1/10 at 10:25 AM |
No Padding im afraid, making mould at the moment to bag press so i will have a formica carbon fibre finish
Hammerhead
| posted on 29/1/10 at 10:32 AM |
wood plane and sandpaper, do it by eye.
suparuss
| posted on 29/1/10 at 10:58 AM |
http://cgi.ebay.co.uk/1-2-SHANK-ROUNDING-OVER-CUTTER-ROUTER-BIT-50-x25-4x19-1_W0QQitemZ400091770465QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?has
h=item5d2753ee61
suparuss
| posted on 29/1/10 at 11:02 AM |
ps- thats a fairly big cutter and any bigger id be wary of putting it in a handheld router. they tend to be only available from the top brand names
like cmt and are uber expensive.
ive got one of these off ebay and it is a decent cutter, certainly will last long enough to do a dash.
PPS- i would have contributed this earlier but im not a contributer apparantly.
Angel Acevedo
| posted on 29/1/10 at 11:57 AM |
Escofina (Rasp)
Its a woodworking tool that looks like a file but has bigger teeth, then sand, fill-sand with template
Confused but excited.
| posted on 29/1/10 at 01:33 PM |
I think you will find that it needs to have a minimum radius of 19mm, if you would care to check the book of words.
