Author: Subject: smal volume simple steel fabrication required
locoboy
posted on 29/1/10 at 09:48 PM Reply With Quote
This seems to be the most appropriate section for this request so here goes.......
I am looking to get a small quantity of metal items fabricated and i dont have the equipment to do it myself, i could make them but it would take ages!
It is essentially a bit of 2mm thick wall unequal box section say 50x30mm cut to length at 625mm with 4 holes(2 different sizes drilled in it at critical spacings.
2 of the holes have a captive nut tack welded inside them (they are near the tube opening so easy to get at.
The bit i couldn't do is that alont its length of 625mm it is cut at a taper from the full 50mm down to 30mm at the other end. This would need the use of a band saw i guess in order to do it accurately and quickly.
I would require approx 60 of these making and i am looking for suggestions of anywhere to get these done, any reccommendations based on your experience, good quality and value for money??
Locoboy
austin man
posted on 29/1/10 at 10:09 PM Reply With Quote
Any locoa engineers / fabrication company should be able to do it and probably glad of the work.
posted on 29/1/10 at 10:15 PM Reply With Quote
Get looking for laser cutters. It should be within their scope to do it then get someone to weld the nuts in or do it yourself.
3GEComponents
Find a local laser company that does tube cutting, this is exactly the kind of thing these machines are made for. They would cut the holes and the taper to a high tolerance.
watch this video....
http://www.laser-profiles.co.uk/video.php
And you'll get the idea.
Kind regards
John
locoboy
posted on 29/1/10 at 10:34 PM Reply With Quote
Kind regards
John
That video was mesmorising! thanks.
That is just astounding how quickly it does what it does, although i was hoping they were goin g to be making somehting and show you the end results!
Any personal reccommendations would be welcommed though.
thanks
Locoboy
Steve Hignett
posted on 29/1/10 at 10:54 PM Reply With Quote
I think I watched that entire video without blinking!!!
Confused but excited.
posted on 29/1/10 at 10:56 PM Reply With Quote
Have you tried Flakmonkey?
locoboy
posted on 29/1/10 at 11:15 PM Reply With Quote
As far as i'm aware he is only into turning at the moment.
Locoboy
boggle
posted on 29/1/10 at 11:34 PM Reply With Quote
you have u2u
u2u me for details
ali f27
posted on 30/1/10 at 01:58 PM Reply With Quote
Hi purdy would do them i will speak to him as soon as i can he is working where there is no signal at the moment
locoboy
posted on 30/1/10 at 03:48 PM Reply With Quote
Thanks for the contact, if you would ask that would be great thanks
Locoboy
designer
posted on 30/1/10 at 04:45 PM Reply With Quote
Go to a local engineers shop and get it all done at the same time: cheaper that way.
locoboy
posted on 1/2/10 at 01:45 PM Reply With Quote
Thats what i am planning on doing, there are a few people on here whoown their own workshops etc and i thought it only right to give them the oppertunity to quote for it.
Locoboy
Valtra
posted on 1/2/10 at 02:02 PM Reply With Quote
Your local agricultural engineer may not be that busy at the moment and pleased of the work
"If it looks like it works and it feels like it works, then it works"
