prelude1980
| posted on 27/2/10 at 04:47 PM |
Sip Migmate
Just a question but the gas valve in the handle has stopped working i've already replaced this a few years ago and it hasn't had much use.
Are these common failures, or can i lubricate it to get it going again or something?
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
Phil.J
| posted on 27/2/10 at 05:28 PM |
Have a look on the Migwelding forum, they have a section dedicated to SIP.
Not a recommended welder to buy, very unreliable according to other users.
rgrs
| posted on 27/2/10 at 06:26 PM |
Take the torch apart , it will be the trigger wire connection in the torch.
It will be a quick fix to get you running again but :
If you replace the torch and modify the pressure rollers then they are fine.
I replaced the standard torch with a euro connector and a good quality torch.
Roger
prelude1980
| posted on 27/2/10 at 06:28 PM |
sorry it's not electrical it's the gas valve not working properly, the valve is in the handle. The valve just constantly leaks
gets you.
Daddylonglegs
| posted on 27/2/10 at 06:46 PM |
My Migmate 130 has also started playing up. The gas valve stays open for a few seconds after I release the trigger. Took it apart and cleaned it but
it only improved it slightly.
If I could afford to change it I would.
prelude1980
| posted on 27/2/10 at 07:38 PM |
i found a replacement swan neck tube with a gas valve for £21 delivered off Ebay.
Was hoping there was a fix not a replacement option
gets you.
Thinking about it
| posted on 27/2/10 at 10:38 PM |
I had the same thing. First strip clean and lubrication did nothing, second time it did the trick.
