Author: Subject: Polishing aluminium
posted on 5/3/10 at 10:38 AM Reply With Quote
Polishing aluminium
My new windscreen frame is made of the usual aluminium extrusions. At the moment it has a good surface (no significant dents, etc) but has the sort of finish you get after rubbing it down with a scotchbrite pad or similar - feels smooth, but has fine scratches.
I want to give this a bit of a polish-up before I fit the glass so that there's little work to do afterwards.
Apart from rubbing it down with the finest paper that I've got (VERY fine!) - can I use a mop and polish in my hand drill to finish it off? If so, what sort of polish would work?
[Edited on 5/3/10 by David Jenkins]
afj
posted on 5/3/10 at 10:46 AM Reply With Quote
On the cheap t cut
eerrrrrrrrrrrrrrrr
Irony
posted on 5/3/10 at 10:47 AM Reply With Quote
salvo autosol
imp paul
posted on 5/3/10 at 10:48 AM Reply With Quote
as above or plain old t cut or g 3 all seem to work hope it goes ok
[Edited on 5/3/10 by imp paul]
mangogrooveworkshop
posted on 5/3/10 at 10:51 AM Reply With Quote
David its buffed with the polishing mop. I think its the fine one. if you want polished get ordinary hand soap and the finest water paper you can get 1200?
Then use sovol autosol and that should bring it up fine
thunderace
posted on 5/3/10 at 11:21 AM Reply With Quote
LOOK UP
Belgom Alu
IS THE ONLY THING TO USE THE REST ARE CRAP
AND BUY A CHEEP POLISHING KIT FROM EBAY AROUND £20 WITH ALU.
posted on 5/3/10 at 11:26 AM Reply With Quote
Thanks Mango!
Thunderace - there's NO NEED TO SHOUT!
Shouting
Shouting
(but thanks for the tip... )
se7en
posted on 5/3/10 at 01:41 PM Reply With Quote
We always used Brasso to clean and polish the Alu wheels on the race cars - brought them up a treat.
posted on 5/3/10 at 02:08 PM Reply With Quote
I should add that I'm not looking for a mirror finish - just a bit shinier that the matt finish I've got at the moment.
I'll have to experiment...
trikerneil
posted on 5/3/10 at 03:44 PM Reply With Quote
Another vote for Belgom Alu here
Neil
ACE Cafe - Just say No.
