fazerruss
| posted on 7/3/10 at 06:53 PM |
Werther lift
Afternoon all , hoping some one can help. Yesterday I managed to get my hands one of these...
http://www.wertherint.com/lang_en/prodotti/autoattrezzature/sollevatori/sollevatori2colonne_2postlifts/pdf/255.pdf
Im after a wiring diagram for it as it had a three phase motor and I intend to fit a single phase but use as much of the existing switch gear as
possible.
Thanks.
"if assholes could fly this place would be an airport"
RichardK
| posted on 7/3/10 at 07:02 PM |
Try emailing them, they maybe able to help you.
Rich
Gallery updated 11/01/2011
| posted on 7/3/10 at 07:08 PM |
Can you actually get 6HP single phase motors?
fazerruss
| posted on 7/3/10 at 07:19 PM |
probably not. Im gonna fit a 4hp as that is what was on the other lift the guy had, and if it struggles ill just fit a reduction gear box or
centefugal clutch
| posted on 7/3/10 at 07:26 PM |
Can't help with the wiring but changing the pulleys will alter the gearing if needed with a lower HP motor
RichardK
| posted on 7/3/10 at 07:28 PM |
Close enough though
Linky
Even with that you've still got a good cheap lift, maybe sell on the 3 phase motor to recover a bit back?
Rich
Confused but excited.
| posted on 7/3/10 at 07:54 PM |
possible.
Thanks.
Jeez dude, you really like those 'Originals'.
irvined
| posted on 7/3/10 at 08:43 PM |
One issue you will have with a single phase motor is reversing it so make the lift go down again.
Your easiest bet might be an inverter, you can pick them up from ebay for ~100-150quid, wiring will then become trivial.
Assuming you fit a single phase motor that can be reversed, you can probably use a lot of the existing switching but for just a single phase. (Ie,
leave the third (and possibly fourth) wires disconnected.)
Good luck!
http://irvined.blogspot.com
Humbug
| posted on 7/3/10 at 08:48 PM |
Is it an original? :p
