StevieB
posted on 11/3/10 at 08:35 PM |
How do you machine internal splines?
As above, just out of curiosity really, does anyone know how internal splines would be machined? For example, the aperture that drive shafts fit into
on sierra rear hubs.
Dingz
posted on 11/3/10 at 08:40 PM |
Generally broached, long tapered profile tool pushed through component.
went on and on.
blakep82
posted on 11/3/10 at 08:41 PM |
do you mean a hole that doesn't go all the way through the metal?
i had my side gears re done to a 18 spline larger than original diameter hole. it was done by wire spark erosion (i think its called)
________________________
robocog
posted on 11/3/10 at 08:44 PM |
http://www.youtube.com/watch?v=pab8MlMYNnc
...An example of broaching
Regards
Rob
v8kid
posted on 11/3/10 at 08:57 PM |
Interesting, so it is a variation of a shaping machine.
I always thought that the broaching tool was the same size as the finished spline for some strange reason. (over active imagination I suppose!)
blakep82
posted on 11/3/10 at 09:15 PM |
i guess it depends on the hole to be splined. a 30mm hole for a halfshaft in a side gear probably would be done in one go, but if its something like
that gear on the you tube video, finding the tool for one that make would be pretty hard i'd think.
Alan B
posted on 11/3/10 at 09:26 PM |
Yes usually it is. Broaching is considered a relatively fast production process. Think of it more like milling but with a long straightened out cutter
that usually takes one pass only.
zilspeed
posted on 11/3/10 at 09:29 PM |
Andy of Waterjet fame made me an adapter with internal splines on it.
Drew it up on CAD, sent hime the file, he cut it with the waterjet. Job done.
Spline pattern fits the input shaft of an escort gearbox. Outside PCD fits a propshat flange.
boggle
posted on 11/3/10 at 09:44 PM |
spline cutting on a waterjet is not recommended over 10mm unless you have a dynamic head...jet wash leads to a tapered finish and a waterjet doesnt
run much more accurate than .2mm....
broaching, wire erosion and spark erosion are the only true accurate was of reproducing any form of involute spline....
u2u me for details
boggle
posted on 11/3/10 at 09:46 PM |
unless broaching a keyway, then shims are used to to take cuts in stages untill at the required depth....
u2u me for details
MakeEverything
posted on 11/3/10 at 10:27 PM |
Do you have a broaching machine?? - You know what the next question is!!!
Kindest Regards,
Richard.
Alan B
posted on 11/3/10 at 10:29 PM |
Yes true, and I should know, I've broached hundreds of keyways just as you say....I was really talking more about mass produced stuff.
boggle
posted on 11/3/10 at 10:36 PM |
me too....builds up the biceps.....
rich.....
no i dont have a broaching machine and i hate getting involved with spline nomenclature.....without all the info to create an involute it will never
be right...
u2u me for details
MakeEverything
posted on 11/3/10 at 10:57 PM |
rich.....
be right...
Just kidding!!
Kindest Regards,
Richard.
