andrew-theasby
| posted on 16/3/10 at 10:41 PM |
whats silver steel?
Im after a bit of what we use to call silver steel at work. I want to braze a drill bit into a 6mm rod about 12" long, but i cant find any on
ebay, and we dont have it at work anymore. Does it come under a different name? Or anybody got something suitable kicking about for beer tokens?
40inches
| posted on 16/3/10 at 10:48 PM |
Try
HERE
fazerruss
| posted on 16/3/10 at 10:50 PM |
i think its silver solder youre after
http://cgi.ebay.co.uk/SILVER-SOLDER-RODS_W0QQitemZ280475567382QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item414da58516
[Edited on 16/3/10 by fazerruss]
"if assholes could fly this place would be an airport"
andrew-theasby
| posted on 16/3/10 at 10:53 PM |
woops, must have spelt it wrong first time, just searched it again to see why i didnt find that one and theres a few results. Thanks
Alan B
| posted on 16/3/10 at 11:35 PM |
Silver steel is form of highish carbon tool steel...usually O1 I believe..
| posted on 17/3/10 at 12:01 AM |
O1 is tool steel, different to silver steel. You can get silver steel or O1 from Cromwell tools.
Silver steel
designer
| posted on 17/3/10 at 07:31 AM |
Why not just buy a long drill?
| posted on 17/3/10 at 07:56 AM |
A length of steel and a 50p jobbing drill bit is a lot cheaper than a 330mm drill bit!
For those who haven't encountered it, silver steel is a bright material (hence the name, not because it has silver in it) with a carbon content
that's significantly higher than mild steel but not as high as tool steel. Saying that, it can be hardened so model engineers frequently use it
for one-off tools. It also comes 'ground round' so it's ideal for tasks such as that of the original poster.
If the other links offered don't work out, send me a U2U - I'll dig out some model engineering sources.
boggle
| posted on 17/3/10 at 08:04 AM |
used to use it for making center punches and small tools....
its also ok for making shear pins....
u2u me for details
