Stuart_B
| posted on 25/3/10 at 06:21 PM |
OT, sds help
hi all, sorry for teh other topic, just wondering if the makita 18v sds drill is any good?
it will be used all the time, manly to drill 5.5, but some times the 20mm long holes
the drill is this one
thanks
stuart
mangogrooveworkshop
| posted on 25/3/10 at 06:23 PM |
thanks
stuart
I have one of these and its fab
http://www.screwfix.com/prods/94332/Power-Tools/Cordless-Drills/Bosch-3-8kg-SDS-Plus-Drill-24V?cm_re=SEARCHPROMO-_-BOSCH%20SDS-_-94332
Does it have to be cordless as I have a corded metabo 110v to sell cheap
[Edited on 25-3-10 by mangogrooveworkshop]
Stuart_B
| posted on 25/3/10 at 06:24 PM |
hi, it does relay, as normal it is when the power is off when i work.
stuart
austin man
| posted on 25/3/10 at 09:17 PM |
I'd go for a 24 volt one if at all possible, Dewalt etc. depends how much you be using it ant any 1 time really
Stuart_B
| posted on 25/3/10 at 09:49 PM |
thanks for the help, the only way i throught about that is because i would have 5 3.0amp battery, all i normaly do would be drilling a 5.5 hole in to
block, rough 50 back boxes, so 100 holes, or 200 holes in a day if i am p cliping.
so not a masive a mount.
stuart
