johnH20
| posted on 25/3/10 at 08:22 PM |
Plastic/chemical metal
I need to build up a small area of the inside of my ali inlet manifold ( approx 1 sq cm by 2 mm deep ) to achieve best flow.
What is the best material to use bearing in mind max temp ( 80 deg C ? ) and more importantly thermal cycling? The area is up steam of the injectors
so fuel resistance is not a major issue.
Obviously I don't want the material to detach and fall into a cylinder. Advice please.
Paul TigerB6
| posted on 25/3/10 at 08:25 PM |
Do you know anyone with a TIG welder??
skinned knuckles
| posted on 25/3/10 at 08:30 PM |
if you were nearer. i'd tig it for you. thats really the only sensible solution.
A man isn't complete until he's married, then he's finished
Paul TigerB6
| posted on 25/3/10 at 08:36 PM |
I'm near - you can do all my welding!!
| posted on 25/3/10 at 08:45 PM |
Technoweld is sticky stuff, very much doubt it would come unstuck. Would need a big blowtorch or pre-heating in a domestic oven though first.
whitestu
| posted on 25/3/10 at 09:12 PM |
I used some chemical metal to do this when I was mucking about with an inlet manifold. It wasn't on the car for long, bt showed no signs of
coming off when I took the manifold off. Always worried me a bit though.
Stu
skinned knuckles
| posted on 25/3/10 at 09:24 PM |
you know how to get hold of me now then don't you
mediabloke
| posted on 26/3/10 at 01:37 AM |
I'm not sure now many compounds would be heat-resistant. Welding would be the safer option.
Different with temporary repairs to other systems, but I'd be like Whitestu - not sure I'd be confident having stuck something to the
inside of the inlet. I'd be too busy listening for a bang... ;-)
