Author: Subject: Help please with compressor
jacko
posted on 2/4/10 at 07:44 PM Reply With Quote
A few months ago the motor on my compressor packed in .
I have found a replacement motor the thing is i don't know which direction the motor / compressor should turn
how can i find out ?
Jacko
hillbillyracer
posted on 2/4/10 at 07:57 PM Reply With Quote
How much will it matter? The valves will only see the piston going up & down & not know the direction of rotation, it's not like a 4-stroke engine where the valves are mechanically operated, it's just the air flow that works them.
The only concern I might have would be if it needed to rotate a certain way for the oil to get distibuted properly.
Does it have a fan built into the pulley? I'd expect it to blow air over the cylinder barrel rather than suck it from it.
splitrivet
posted on 2/4/10 at 08:00 PM Reply With Quote
Has the flywheel got fins if so airflow should be going from the flywheel to the pump.
Bob
jacko
posted on 2/4/10 at 08:07 PM Reply With Quote
Yes it has a fan built in the pulley
A1
posted on 2/4/10 at 08:23 PM Reply With Quote
there should be a marking on it somewhere. usually the fan housing.
