indykid
| posted on 4/4/10 at 12:08 AM |
10mm throat butt weld
i know there are a few pro welders on here so my question is if someone said i want a 10mm throat butt weld on a lump added onto a 32mm bar, would you
laugh at them, or would you just get on with it?
detail behind the question's in the next post
cheers
tom
indykid
| posted on 4/4/10 at 12:10 AM |
a part of my final year project, i've been working on the design of a drop weight impact rig for the testing of composite materials.
dissertation's due in next monday but i'm just working through my final designs of the bits that aren't to be machined yet.
i've been doing a weld stress calc on the safety stop which is a 32mm dia en8 bar with a 27mm wide lump of en3a welded onto it.
when the sled falls from 2.5m, max drop height, assuming the 29kg sled's brought to rest in 6milliseconds on a pair of bullet shaped bump stops,
the calc suggests i need a 10mm throat butt weld all round.
is that....possible? i imagine it needs more than one pass but we have 250amp mig and a monster stick kit in uni. i don't have to actually weld
it but it'd be nice to come up with a design that's actually feasible.
it will leave an unwelded section on the back face but it's not going to be subjected to any real cyclic load. it will possibly be impacted once
in a blue moon when my control system fecks up.
tom
daviep
| posted on 4/4/10 at 08:02 AM |
I don't understand the question I think a drawing would probably make it a bit clearer.
Regards
Davie
smuty
| posted on 4/4/10 at 09:14 AM |
cheers
tom
think its a 10mm fillet weld your after
indykid
| posted on 4/4/10 at 10:36 AM |
this is what i mean.
the top of the square face would be impacted if the sled ever hit it.
i could increase the length of the bar to give a fillet weld top and bottom but there's no room for it on the sides
thiking about it, i'll probably spec it as that just to save messing with trying to bevel the round face.
any other thoughts though, keep them coming.
cheers
tom
MkII
| posted on 4/4/10 at 11:38 AM |
from what I can see on your drawings if it was prepared and welded properly the 2 pieces would never come apart.....ever. .m.
blakep82
| posted on 4/4/10 at 11:41 AM |
looks plenty strong to me.
if this was for a one off thing, but high use, then the cost of getting something cast in one solid piece could probably be justified?
________________________
skinned knuckles
| posted on 4/4/10 at 11:51 AM |
X2
A man isn't complete until he's married, then he's finished
indykid
| posted on 4/4/10 at 12:24 PM |
cast and impact sounds bad to me.
bringing a 29kg plate travelling at 7m/s to rest in 6 milliseconds requires an average force of 40600N......4.1 tonnes in static terms
i think it looks strong enough too. the maths agrees but it's the technicalities of producing the weld i need to know about.
it's a 2 off btw so casting/forging are not an option
ta
tom
jacko
| posted on 4/4/10 at 12:27 PM |
Yep looks good to me thats how i would do it
Jacko
indykid
| posted on 4/4/10 at 12:48 PM |
Jacko
just the man!
cheers graham
tom
blakep82
| posted on 4/4/10 at 01:04 PM |
ah yeah, not casting then, but who about machining on a CNC mill or something?
indykid
| posted on 4/4/10 at 01:10 PM |
that's more feasible.
could turn it down from bigger bar then mill the sides off, but the EN8 i have at uni is bright rolled.
not got any cylindrical grinding facilities at uni and i need a smooth finish for the plain bearings it rotates in. if it were turned, i could spec
needle roller bearings but that introduces more complexities than it solves
tom
Mark Allanson
| posted on 4/4/10 at 01:11 PM |
Just weld with low hydrogen rods, the weld will be stronger than the parent material. E6011's from memory, but make sure they are ultra dry when
you use them (use a heated quiver)
stevebubs
| posted on 4/4/10 at 02:52 PM |
Whatabout a thick dowel through the pair of parts?
gazza285
| posted on 4/4/10 at 08:42 PM |
E7018. You need a DC set for low-Hys as well. If you are going to that much trouble, then why not go for full pen? Wouldn't take much more
effort, as long as the guy welding it is coded for full pen.
iank
| posted on 4/4/10 at 08:50 PM |
My understanding is a machined forging would be better than either cast or CNC milled from billet. (due to the crystalline alignment)
But a welded part would seem to be up to the job if done by a professional welder.
Anonymous
