speedyxjs
posted on 10/4/10 at 12:39 PM |
What compressor 2
The earlier thread reminded me of something i need to ask.
Im in the process of setting up a garage doing servicing, repairs and MOT's aswell as small restoration/engineering jobs.
Can anyone tell me what sort of CFM i should be looking for in a compressor. id ideally like to spend less than £1k but may be able to stretch to
£1500/£2k.
big_wasa
posted on 10/4/10 at 12:54 PM |
You can never have to much air. So the more the better.
blakep82
posted on 10/4/10 at 12:57 PM |
biggest you can afford really.
i bought a clarke one for about £500 (thats how much they are now, sure it was only about 350 when i got it) and never run out of air yet.
needs a 32amp circuit though.
________________________
speedyxjs
Forgot to add that it will need to be quiet as teh landlord is fussy (but could be put in a sound proof box).
big_wasa
posted on 10/4/10 at 01:01 PM |
Will you have 3 phase as single will really limit what you can run.
blakep82
posted on 10/4/10 at 01:02 PM |
oh yeah, mines single phase too.
quite noisy when it starts up, but when the tank's full it only runs when it drops below a certain pressure. if all your air lines are nicely
sealed it shouldn't need to run unless you're using it
[Edited on 10/4/10 by blakep82]
speedyxjs
posted on 10/4/10 at 01:05 PM |
Yeah, will have 3 phase.
Ivan
posted on 10/4/10 at 02:08 PM |
I would guess at finding out what air rate a good air wrench uses and get something about 4X that rate.
Stuart_B
posted on 10/4/10 at 02:34 PM |
i have 19cfm, but that is just me and some times my dad work at the same time, but if you have 3 phase you can go in to a lot more.
if you have a 1k to spend, see what the highest spec bit off kit you can get.
stuart
speedyxjs
posted on 10/4/10 at 05:56 PM |
Ok, cheers guys
Canada EH!
posted on 10/4/10 at 07:10 PM |
Check the requirements of your air tools. Sanders, sandblasters, and air grinders require alot of air.
The bigger the tank the better, big tank will make it possible for a small compressor to keep up for short periods of time.
