Author: Subject: Destroying a bodyshell
Snuggs
posted on 14/4/10 at 04:15 PM Reply With Quote
What size angle grinder and type of cutting disc would be most suitable to cut up a bodyshell ?
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Dingz
posted on 14/4/10 at 04:17 PM Reply With Quote
An axe
went on and on.
hughpinder
posted on 14/4/10 at 04:19 PM Reply With Quote
I've chopped up several using a six foot straight crowbars - chisel end.
Takes about 3 hrs to reduce a large saloon to 18 inch squares. I cut the top of the window posts first.
Regards
Hugh
hughpinder
Regards
Hugh
redscamp
posted on 14/4/10 at 04:21 PM Reply With Quote
230mm as thin as possable
zilspeed
posted on 14/4/10 at 04:48 PM Reply With Quote
YKIMS.
r1_pete
posted on 14/4/10 at 04:59 PM Reply With Quote
But youd be fitter after using a regular axe.... Rescued attachment gasaxe.jpg
posted on 14/4/10 at 05:02 PM Reply With Quote
Good old stihl, had the front end of mine off in 20seconds
dhutch
posted on 14/4/10 at 05:06 PM Reply With Quote
mcerd1
posted on 14/4/10 at 05:07 PM Reply With Quote
I only had a big persuader [sledge hammer] and a hacksaw so it took me a whole 10min to get the front off my donor
but the second time I used an even bigger persuader
mangogrooveworkshop
posted on 14/4/10 at 05:12 PM Reply With Quote
Find your local banger guys they want them....may even give you money
steve m
posted on 14/4/10 at 07:50 PM Reply With Quote
I used an axe on an old mini, took about 30 mins, and all the bits went inside my old rover SD1, and down the tip
I kept the SD1 !!!
jacko
posted on 14/4/10 at 09:01 PM Reply With Quote
-reciprocating/alligator saw
