karlak
| posted on 19/4/10 at 01:09 PM |
Powder Coating costs
Just after peoples experience of Powder Coating Costs. Looking at getting the front suspension arms re-done. I guess these companies will/can shot
blast it as well ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
bbwales
| posted on 19/4/10 at 01:18 PM |
I had my wishbones shot blasted and powder coated for 30 quid. HTH
Bob
richardlee237
| posted on 19/4/10 at 01:24 PM |
front wishbones, rear trailing arms, engine mounts,rocker box cover
Blast and coat, nice job
20 squids
result, I reckon
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
karlak
| posted on 19/4/10 at 01:47 PM |
Thanks Guys,
Seems a bit more expensive round Milton Keynes area - looking at Minimum charges from £50 and that does not include shot-blasting
cd.thomson
| posted on 19/4/10 at 01:56 PM |
keep looking. I took my engine cover to a big industrial place where the powder coat train parts.
Cash in hand job but they helped me out with colours, properly prepared it for me (underside just needed masking off but still..), shot blasted and
painted it in a day for a tenner.
If it was just a case of blasting and painting my wishbones black I'm sure they would have done it for £30
Craig
sucksqueezebangblow
| posted on 19/4/10 at 02:22 PM |
Got my Stainless Steel grille done for 20 smackers (donation to the coffee tin)!
big_wasa
| posted on 19/4/10 at 03:16 PM |
Dearer around here aswell. Dont powder coat anything thats not been blasted.
It will just come of in sheets
| posted on 19/4/10 at 03:19 PM |
4x Indy bones, rear uprights and rack extensions all blasted and coated black for £45 cash
Hugh_
| posted on 19/4/10 at 04:03 PM |
I'm having my rear arches blasted and coated at the moment, and enquired about wishbones and roll bar while I was there; £10 per wishbone and
£30 for the roll bar (no stays).
piddy
| posted on 19/4/10 at 04:33 PM |
I had my front wishbones and cycle wing brackets done for £35.
Zetec rocker cover done for £35.
Both were blasted and then coated.
adrianreeve
| posted on 19/4/10 at 06:40 PM |
I had my chassis, rollbar, wishbones, uprights, pedals, caliper carriers, cam cover, engine pullies and a host of other little brackets etc. blasted
and powdercoated in satin black for £200. Makes a great start to your build.
suparuss
| posted on 19/4/10 at 09:20 PM |
you can get half a lite of g4 pond sealer for about £12. i painted the roof rack on my disco with it and it gets quite a bit of abuse, not to mention
being under constant attack by the ellements and has stood up very well and has turned a quite fetching matt black over time.
youd need to have them 100% clean and rust free. it is basically a moisture cured polyeurethane (isocyanates so beware of fumes!) and is used for
sealing ponds, tanking and priming metal and concrete for grp as well as boat related stuff. if i ever build another chassis ill be painting it with
pond sealer.
edit- eeeeek, just realised this was my 666th post!
[Edited on 19/4/10 by suparuss]
