Author: Subject: Spring compressors? Lowering an a4
Kriss
posted on 20/4/10 at 10:29 PM Reply With Quote
I'm shortly picking up an a4 and want to drop it a few mm on springs. However I am sure I need to compress the spring to remove.
And locost ways of doing so or cheap supplier of the correct tool?
Will be a 2003 a4 avant Tdi sport
Miks15
posted on 21/4/10 at 07:17 AM Reply With Quote
what i did was make to hook king of things out of some pretty thick steel, the welded one on to one end of a threaded bar, the welded the other on to a tube that slides over the threaded bar.
Then a nut and big washer pushes the tubed one towards the welded on compressing the spring.
ETA piccy: hope this makes sense
Image deleted by owner
[Edited on 21/4/10 by Miks15]
indykid
posted on 21/4/10 at 08:14 AM Reply With Quote
ffs! they're £20 a pair at halfords.
having had a spring jump out of a spring compressor before, DO NOT scrimp on this.
sorry miks but there's no way i'd use that style ever again. get the proper 2 finger ones
tom
Steve Hignett
posted on 21/4/10 at 10:10 AM Reply With Quote
Originally posted by indykid
ffs! they're £20 a pair at Halfords...
tom
pmsl...
indykid
posted on 21/4/10 at 10:22 AM Reply With Quote
tom
pmsl...
ChrisW
posted on 21/4/10 at 10:30 AM Reply With Quote
P'ing MySelf Laughing
Who needs spring compressors anyway? Just point them down the garden and undo the top nut very slowly making sure you don't lean over the spring.....
Chris
PS: Do not do this!!
indykid
posted on 21/4/10 at 10:54 AM Reply With Quote
i understand that bit, just wasn't sure what was amusing about the rest.
i lost a fair chunk of skin off my index finger (luckily not the whole lot) and it nearly broke my dad's knee. he was hobbling for weeks
don't understimate coil springs and don't go locost on the tools
tom
Kriss
posted on 22/4/10 at 04:20 PM Reply With Quote
my buddy has compressors so all good.
cheers again!
Mark Allanson
posted on 22/4/10 at 04:25 PM Reply With Quote
DON'T DO IT!!
The A4 has S curve front suspension and has the finest setup system of any car on the market. It can take hours to get it right.
If you lower the car, the design will be compromised and you will end up with a foul handling car.
Steve Hignett
posted on 24/4/10 at 06:09 AM Reply With Quote
tom
Was laughing because it was a correct but abrupt response and made me giggle - basically, it was exactly what I had in my head to respond with until I saw yours
RK
posted on 24/4/10 at 12:33 PM Reply With Quote
Well in Canada, all the imported cars are jacked up about 10 cm over what you have in the UK or Europe, so don't talk about bad handling!! I am sure they don't do anything else to the suspension to make up for that little mod required by the idiots at Transport Canada. There is nothing more stupid looking than a nice car jacked up to look like a 4x4, with tiny profile tyres and small rims.
I would also be interested in lowering my A4 Avant.
ps... handling for me improved 1000% when I put Bridgestone Potenza RE 11's on. Unbelievable difference to previous rubber.
[Edited on 24/4/10 by RK]
