blakep82
| posted on 9/5/10 at 10:54 PM |
hacksaw blades for cutting aluminium
how many teeth per inch do i want again?
________________________
indykid
| posted on 9/5/10 at 11:10 PM |
how thick's the thing you're cutting?
coarse is always good for aluminium to stop the blade clogging, but not too coarse.
for steel i think the rule's something like 3 teeth + on the workpiece
tom
blakep82
| posted on 9/5/10 at 11:11 PM |
ah, right its 1.6mm tube, so probably want quite a few teeth then? stop it snagging?
flak monkey
| posted on 10/5/10 at 06:51 AM |
18TPI for tube, 14 for thicker plate otherwise they just clog up.
You should have more to have 3 teeth in contact, but there we go
Sera
http://www.motosera.com
| posted on 10/5/10 at 07:14 AM |
A good trick when filing aliminium is to rub talcum powder on the file before filing. When the teeth get clogged full of the ali just give it a tap
and all the ali falls out
| posted on 10/5/10 at 07:44 AM |
Or rub a stick of chalk along the file - same effect.
If you're not going to paint the piece (or are prepared to do some clean-up afterwards) then a squirt of wd40 is very helpful.
