Author: Subject: Drilling problem...
DaveFJ
posted on 17/5/04 at 12:45 PM Reply With Quote
Drilling problem...
Ok here's my problem...
I need to drill some awkward places where access is awful
If I still had access to the aircraft tooling I would use a right angle, collet type windy drill - however I don't so that's no good.....
I tried using one of those flexi drive things from stanley - bloody crap plus it nearly broke my fingers!
I have seen the right angle cordless drills for hire but the are just too bulky to get into the corners I need
So has anyone else come up with a solution to this problem ?
I don't have a compressor at the mo so that would be an extra expense if I did find a suitable air drill... (one on ebay at moment for £30+
Dave
mangogrooveworkshop
posted on 17/5/04 at 02:21 PM Reply With Quote
I bought a right angle drill attachment from ebay. 6 quid but if you are needing one in a hurry machinemart do em for a tenner. Ive used it for alsorts
posted on 17/5/04 at 03:25 PM Reply With Quote
I have a small right-angled drill attachment you can borrow if you want. OK for small holes, but it's almot impossible to get enough weight behind it for larger drills.
Useful though! (and I'm in the same town, of course)
DaveFJ
posted on 17/5/04 at 03:42 PM Reply With Quote
That would be excellect Dave
Only drilling 3mm so should be ok.... ?
when you say 'small' - how small ?
I only have about 3" clearance...
Regards
[Edited on 17/5/04 by protofj]
Dave
posted on 17/5/04 at 03:44 PM Reply With Quote
I think it's got a 10mm capacity chuck attached to a right-angled bend, then about 4" or 5" shaft, then a stub that you put in the chuck of your electric drill.
The hardest part is holding it on-target, and giving it enough 'push'.
Send me a u2u and I'll make some arrangements when I log in tonight.
tractorboy
posted on 20/5/04 at 09:07 AM Reply With Quote
if you do find yourself with a compressor give me a shout. by proffesion im an airframe fitter and have various sized and angled drills and im just up the road and wont need much of an excuse to get out and about if i can get through my sva re-re-test on monday
DaveFJ
posted on 20/5/04 at 09:21 AM Reply With Quote
Good luck with your re-test
Can't wait to actually see a finioshed avon on the road
Airframe fitter - where/who for ?
(I did 15 years on airframes/engines)
Dave
tractorboy
posted on 22/5/04 at 06:33 AM Reply With Quote
i work at marshall aerospace in cambridge on the c130 hercules.have been there for 8 1/2 years
