neilp1
| posted on 17/5/10 at 10:08 PM |
3 in 1 TIG welder
Seen this on the bay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190397646325&ssPageName=STRK:MEWAX:VRI
Anyone got one? any good??
| posted on 17/5/10 at 10:10 PM |
That's way too cheap for a proper TIG
mcerd1
| posted on 17/5/10 at 10:15 PM |
assuming its on of those inverter ones - my dad's got one for stick welding in places that you can't get a proper welder close enough
(like the top of a ladder)
even with the TIG torch - you can't TIG alloy with them apparently
ReMan
| posted on 17/5/10 at 10:41 PM |
Is it just the inverter add on?
Mr G
| posted on 17/5/10 at 11:40 PM |
This is a picture associated with the model number on the ebay listing
HE
RE
Product Description:
Model: CT-312 (D) , CT-416 (D) , CT-518 (D)
1. Advanced inverter technology, reduced size and weight, easy to carry.
2. Novel and effecitive, and low cost;
3. Three functions in one machine, tig welding, mma welding and air plasma cutting
4. Compact and easy for operation.
5. "D" Series are for 110 / 220 duel voltage input, automatic input voltage changing
6. Complete accessories: welding torch, welding cable (3 m) , earth clamp, welding holder, , cutting torch, carton box.
Full spec
HERE
G
[Edited on 17/5/10 by Mr G]
wilkingj
| posted on 18/5/10 at 05:55 AM |
You need an AC TIG to weld Alluminium.
These are DC Tig's and will not weld alluminium.
I paid £198 for my 200A DC Tig. I'm happy 2 years on, and it welds OK.
To get a plasma cutter thrown in for just a little more money, but only 160Amps instead of 200Amps. It's not that bad a deal.
I dont think its way to cheap, but probably about right for a Far Eastern Tig set with those capabilities
Best Regards
Geoff
http://www.v8viento.co.uk
iank
| posted on 18/5/10 at 06:27 AM |
Good to see the cheapies are starting to include HF start.
Anonymous
| posted on 18/5/10 at 07:43 AM |
DC only inverters have been available around this price for quite a long time. You can get AC/DC TIGs for £400. However, the quality of these is
typicaly Chinese, i.e. varies from crap to mediocre.
If you are tempted my advice would be to check out the price of Argon in your area. The thought of paying yearly rent on a bottle that would not be
used very often put me off, but there are some places in the country that you can just put a deposit down on a bottle and have no rental charges.
Sadly none down here that I have found.
skinned knuckles
| posted on 18/5/10 at 07:57 AM |
personally i would go for one of the AC tigs that doesn't have the plasma cutter try a WSE 200. that way you can have a go at ali welding.
in my experience the 3 in one machines dont do anything well, but do everything OK. i'd rather just jave the welder that works peoperly.
A man isn't complete until he's married, then he's finished
iank
| posted on 18/5/10 at 08:07 AM |
I've seen this place recommended, they ship the gas using TNT with no rental.
http://www.adamsgas.co.uk/stat_ind_product.aspx?ctrl=argon
Still more expensive than MIG gases at £43+vat for 9L and some hefty delivery charges but better than paying a rental for hobby use.
[Edited on 18/5/10 by iank]
Anonymous
v8kid
| posted on 18/5/10 at 10:26 AM |
My bro in law uses one of these as a stick welder on his boat and they are excellent. Because it is DC it works really well with stick welding with a
classic weld and the slag peels off perfectly.
He welded up 4 aux fuel tanks out of quarter plate for the boat ( its a large boat) and they all passed air pressure test first time - not bad for an
amateur and says a lot for the welder.
The tig torch that came with it looks a bit naff I'll try it out this weekend but don't have high hopes.
Strontium Dog
| posted on 18/5/10 at 04:46 PM |
You can get bottles from Bodmin, I have one for when my air product account finishes. The gas costs more of course but there's no rental so if
you don't use it often it's the way to go!
Here's a link to the supplier
http://www.rusesgasandtools.co.uk/
| posted on 20/5/10 at 09:13 AM |
Thanks for that, Bodmin's not too far at all.
