eznfrank
posted on 31/5/10 at 10:25 AM |
Is it possible to get a nice finish on sikaflex like you can with silicone?
As above, I was just wondering if you can get a nice finish on sikaflex and if so, how?? I can get a really nice finish with silicone having spent
many a summer labouring for my dad who is a tiler, but wasn't sure if sikaflex would be the same, mainly cos I usually use a wet finger for
silicone.
indykid
posted on 31/5/10 at 10:27 AM |
a finger dipped in fairy was which kit's tip but i found brake cleaner is good for tidying up and works well as a solvent
tom
Tipster69
posted on 31/5/10 at 10:40 AM |
I've used Sikaflex quite a lot on my Motorhomes. You need some "Fugenboys", you can get a brilliant professional looking finish
with them.
http://www.screwfix.com/search.do;jsessionid=AVPYBKYT4VFLUCSTHZOCFFA?_dyncharset=UTF-8&fh_search=fugenboy&searchbutton.x=0&searchbutton.y=
0&searchbutton=submit
[Edited on 31/5/10 by Tipster69]
RazMan
posted on 31/5/10 at 04:24 PM |
I found that meths is a good cleaner and if you moisten the top surface before it goes really hard you can use the finger technique to polish the
surface with good results
[Edited on 31-5-10 by RazMan]
Raz
lee@RRR
posted on 31/5/10 at 08:36 PM |
swafega wiv water on a latex glove works realy well or tyre soap can make it really smooth and the swafega just dry's off as does the tyre soap
