RedAvon
| posted on 18/6/10 at 11:17 AM |
Gas regulator Clarke MIG 151TE
Advice please - have a new Clarke 151TE with the small gas bottle and regulator shown and i want to swap to the big bottles using the full size
regulator.
The pipe on the MIG is only as big as a straw and disappears into the welder - I guess i would be best to swap this for 6mm pipe?
what bits do I need and should i take the welder apart to swap the tiny pipe or does this go all the way to the nozzle?
[Edited on 18/6/10 by RedAvon]
RedAvon
| posted on 18/6/10 at 11:20 AM |
can't upload pics sorry
r1_pete
There are conversion pipes available like
this one , then you need the regulator & bottle.
RedAvon
| posted on 18/6/10 at 11:23 AM |
I have this regulator - if the pic appears - if not its a Saffire with pressure and flow dials.
t16turbotone
| posted on 18/6/10 at 11:39 AM |
i have same welder as you, i just extended the 4mm nylon line with push fit straight coupler, and then connected into regulator with appropiate push
fit pneumatic fitting
tony
MikeCapon
| posted on 18/6/10 at 12:03 PM |
Hi.I had the same prob. This thread may help.
Mike
RedAvon
| posted on 18/6/10 at 02:15 PM |
Thanks for your replies chaps - can work it out from here - just need to sort out my pic posting now!
