Author: Subject: Anti-roll bar quick how to please
matt_gsxr
posted on 8/7/10 at 08:31 PM Reply With Quote
So, I have an ARB on the front of my Phoenix and it seems a bit stiff, I have run the calcs and it is too stiff. So I need to make up another.
My question is how?
I have inboard suspension and all the mountings, so I know the dimensions. It is going to be 400mm long, and needs 5inch arms at 90deg to the bar. Material wise 1/2 CDS with a 3.25mm wall thickness seems to make sense.
But, how do I fit the arms to the bar?
Weld them? Use a longer bar and bend it with a bit of heat.
I could make it from 1/2inch solid if that would help.
Thanks,
Matt
smart51
posted on 8/7/10 at 09:13 PM Reply With Quote
Could you add extensions to the arms of the current bar? The extra leverage would make it seem softer.
Have a look at the caterham website. They sell ARBs in a variety of thicknesses. One of them might fit.
hicost
posted on 8/7/10 at 09:32 PM Reply With Quote
Drop Links
Use Drop Links
"I cant do that without accidentally grabbing hold of the work of the divine potter"
loggyboy
posted on 8/7/10 at 09:33 PM Reply With Quote
Machine/grind/file an area of the bar to make narrower and flex more?
Steve Hignett
posted on 8/7/10 at 09:48 PM Reply With Quote
ARB shizzle...
http://www.merlinmotorsport.co.uk/SUSPENSION-Associated-Suspension-Parts-Roll-Bar/c31_32_33/index.html
matt_gsxr
All the Caterham ones are too long, as I am running my drop links from the top of the rockers. Actually I am not sure about the front CSR ones, these are shorter, but still look a bit too long. So I need a bar of around 400mm long.
If I make the arms longer, you are correct it would have the same effect. Unfortunately the arms are already long. As they get longer the front-back forces on the rocker get nasty. So I am at the limit of the arm length.
I already have drop-links.
Good thought on grinding down the existing bar. The only problem with that route is that it is a bit irreversible! It is something that I am considering though.
I have read some stuff on this, and generally welding the ARB is considered a bad idea. I might get some 1/2inch rod and put some bends in it (cold).
Here is an interesting link from a US locost site:
Linky
Matt
CNHSS1
posted on 9/7/10 at 09:52 AM Reply With Quote
The Allan Stanniforthe books, Race & rally Car Data Source book, and competition car suspension, show the calculations from mike Pilbeam and David Gould respectively on designing ARBs.
Luckily you already have one, so using the calcs it'll be relatively simple to find the diameter and/or length required to give the results you need.
As for making one up its not rocket science, CDS tube can be used (bit lighter than solid bar) and can be mandrel bent cold. if you cant get CDS tube in the sizes required, use hydraulic tube (essentially the same stuff) availaible from most commercial hose suppliers (used to repair plant machines and JCBs).
Ive used the merlin style plastci clamps and they work great although MUCH cheaper from the hydraulic suppliers
CNHSS1
posted on 9/7/10 at 12:43 PM Reply With Quote
ooops, engaged brain and re-read your first post properly
welding arms to the tube is easily done and ive had a few done like that with no ill effects, although theory dictates its not ideal. Normally use 4mm flat plate for the 'arms' and drill a few holes either side of the normal mounting position to give some adjustment. with 5" arms, possibly only one hole either side of the ideal would give quite a variance in stiffness.
alternatively have the tube mandrel bent as i prev mentioned, and then teh Merlin red ally sliders will give you finer adjustments sliding along the 5" lever arms
HTH
CNH
matt_gsxr
posted on 10/7/10 at 09:47 PM Reply With Quote
I might remanufacture a bar/tube using the bending method.
Excellent advice there mr CNH.
In the mean time I decided that the easiest thing was to take my 16mm bar and "trim" it down a bit.
I started with this,
ARB1
ARB1
and [after 2hours of grinding, filing, sanding] ended with this;
doctored_ARB
doctored_ARB
16mm diameter, down to a bit less than 13mm. Which reduces the stiffness by a factor of 2 or so.
For what its worth, making a bar in this way might be a good method (especially if you had a lathe) as the weld are on a thick section (limited flex, and hence chance of failure at the welds which won't flex so well) but you can tune the bar to the required stiffness.
Thanks for all the help on this
Matt
[Edited on 10/7/10 by matt_gsxr]
