interestedparty
| posted on 15/9/10 at 05:11 PM |
Tools someone should invent-
First on my list would be something along the lines of a small angle grinder, with which I could reach into a narrow space and cut through a rusty nut
and/or bolt, and so release an exhaust component without having to damage it.
Alternatively, something like a pincers, but much stronger and maybe powered by hydraulics, that could do the same job.
I've had nut splitters in the past, but don't think I ever came across a situation where there was enough space to actually use it.
Benzine
| posted on 15/9/10 at 05:19 PM |
a torch that only shines on things worth looking at
Jon Ison
| posted on 15/9/10 at 05:50 PM |
A bag of assorted holes.
balidey
| posted on 15/9/10 at 05:55 PM |
a drill bit that makes the holes smaller after you realise you drilled it too big
Dutch bears have terrible skin due to their clogged paws
| posted on 15/9/10 at 06:31 PM |
A Dremel with cutting disc???
I've used one (successfully) for that very purpose!
It's Evolution Baby!
carpmart
| posted on 15/9/10 at 06:48 PM |
As Scootz says, that tool is already here... its called a dremel!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
interestedparty
| posted on 15/9/10 at 06:49 PM |
I did think of that, but they cut in the wrong direction (unless there is an angle version that I'm not aware of). I'd never be able to
get the body of the dremel in there.
Thanks for the suggestion anyway
iank
| posted on 15/9/10 at 07:10 PM |
Could be sold in a set with a hole moving tool for when you realise it's in the wrong place.
Anonymous
| posted on 15/9/10 at 07:12 PM |
You need a Dremel Flexi-Shaft attachment!
scudderfish
| posted on 15/9/10 at 07:27 PM |
Just reverse the direction of the drill and it'll pull the swarf back in to fill it.
Ben_Copeland
| posted on 15/9/10 at 08:07 PM |
How about a tool location finder, or tool radar for all tools that you put down next to you while working, reach over to get it and its gone for the
next hour+
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
interestedparty
| posted on 15/9/10 at 08:53 PM |
I don't see how that helps, the handle part is almost as wide as the motor. And the cutting action is going to be at right angles to the shaft.
I expect it would be better than what I have now, but what I really need and want is a minature angle grinder (but with a decent depth of cut
| posted on 15/9/10 at 08:58 PM |
I know exactly what he means - a mini angle-grinder. For example, a dremel with a cutting disc that spins at 90 degrees to the axis of the motor.
I've needed something similar myself in the past.
mad4x4
| posted on 15/9/10 at 09:01 PM |
Is that ney called a Mig welder....
Scot's do it better in Kilts.
iank
| posted on 15/9/10 at 10:19 PM |
Do they work on fibreglass?
Anonymous
dhutch
| posted on 15/9/10 at 10:41 PM |
Yeah, its still no angled.
Recip air saw is all i know of, but there awful....
stevebubs
| posted on 16/9/10 at 01:48 AM |
Spark erosion is what you need...
http://ezinearticles.com/?Homemade-Wire-EDM-Machines&id=407705
[Edited on 16/9/10 by stevebubs]
| posted on 16/9/10 at 09:26 AM |
Why are they awful? Mine has cut through several seized suspension bolts now, in fact it was purchased for that very job.
I've also used a Dremel clone to cut through a seized exhaust bolt on my MR2, but was a very tight fit and ended up with red marks all over my
hand as it was wedged in place so tight.
boggle
| posted on 16/9/10 at 11:57 AM |
yes
u2u me for details
coyoteboy
| posted on 16/9/10 at 12:59 PM |
Fein saw?
http://www.youtube.com/watch?v=Oox1PxR-2W8&feature=related
interestedparty
| posted on 16/9/10 at 03:08 PM |
quote: Originally posted by coyoteboy
Fein saw?
I've had a Multimaster for years, but basically the body is too big to get in this particular gap, I'm not convinced it would have the
power either.
Interesting suggestion, though, I will maybe experiement if I can make more space.
