keith777
posted on 22/9/10 at 05:10 PM |
pinto head
Hi guys, will an injection head fit a standard pinto block [not 205] cheers Keith
karlak
posted on 22/9/10 at 05:16 PM |
I am pretty sure the answer is yes, but others should be along to verify this for you.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
snapper
posted on 22/9/10 at 05:26 PM |
Most definatelly yes, it's unleaded and worth 5 to 10 bhp more just because of the better short side turn under the inlet valve.
If you are just going to fit it without any modification then but a Felpro 1mm gasket, this raises compression to 9.7 to one, add an FR285 and you
should se over 130 bhp
[Edited on 22/9/10 by snapper]
I eat to survive
I drink to forget
robertst
posted on 22/9/10 at 05:47 PM |
will it fit the 205 block? (sorry, didnt mean to hijack)
[Edited on 22/9/10 by robertst]
Tom
snapper
posted on 22/9/10 at 06:07 PM |
All pinto heads will fit all blocks but beware your compression ratios fitting a 1.6 head to a 2.0L or 2.0L to a 1.6 will be wrong.
For the 2.0L engine any 2.0L head will fit but the 2.0L injection head is the best
I eat to survive
I drink to forget
mcerd1
posted on 22/9/10 at 07:24 PM |
apart from the extra strength / weight all the 2.0 blocks are the same - so you can use any of the heads (as above)
even the cossie blocks are the same
but fitting a cossie head needs a few other bits to make it work (but then it is a 16v alloy head)
[Edited on 22/9/2010 by mcerd1]
keith777
posted on 22/9/10 at 08:00 PM |
Thanks guys !!
