Author: Subject: Longshot - huge countersink bit?
RazMan
posted on 8/12/10 at 04:30 PM Reply With Quote
I'm looking for a 40mm ish diameter countersink bit. I want to make a small 'lead in' on my throttle bodies which are 35mm dia. Ideally I just need to borrow one for a day or two but if one is available for a reasonable price I might be able to find some beer tokens
Raz
MikeCapon
posted on 8/12/10 at 04:33 PM Reply With Quote
Valve seat cutter???
RazMan
posted on 8/12/10 at 04:53 PM Reply With Quote
Now why didn't I think of that?
Raz
Fred W B
posted on 8/12/10 at 05:01 PM Reply With Quote
Or any cutting tool (router bit?) designed for wood will work fine - assumiming the parts are ally.
Fred W B
RazMan
posted on 8/12/10 at 05:18 PM Reply With Quote
Good call Fred
Raz
matt_gsxr
posted on 8/12/10 at 06:40 PM Reply With Quote
Or even a deburring tool, these work nicely on aluminium. If you just want to take a little off.
http://www.cbsonline.co.uk/swivelling-blade-deburring-tool-swdeb-838-p.asp
RazMan
posted on 8/12/10 at 09:35 PM Reply With Quote
Cheers Matt, I think the router bit like this one
would be the best option as it gives a rounded profile which is perfect for gas flow. I just need to find one at B&Q (that one is only £7 but from Hong Kong) or similar - only need a cheap one as it will only get used once or twice.
*edit* Just found one on eBay for £7 and free p&p
[Edited on 8-12-10 by RazMan]
Raz
Fred W B
posted on 9/12/10 at 11:33 AM Reply With Quote
Just make sure you turn it carefully/slowly, maybe by hand?
Fred W B
[Edited on 9/12/10 by Fred W B]
posted on 9/12/10 at 12:05 PM Reply With Quote
The thought of applying that router bit to the end of an aluminium tube terrifies me...
...they're scary enough when used on the edge of a big slab of wood!
RazMan
posted on 9/12/10 at 12:32 PM Reply With Quote
Yes, and in the cold light of day I have had slight re-think (I had dreams about flying swarf last night )
I think a golf ball with a bolt through the middle might act as a shaped holder for some emery cloth. Using a cordless drill and pushing the ball/emery into the opening of the TB, it shouldn't take too much effort to give me a small lead-in.
Raz
MikeR
posted on 9/12/10 at 12:39 PM Reply With Quote
but it has given me an idea ..........
What is the opposite shape to the "rounding over" shape?
Ie the rounding over bits 'cut' is the inside of a circle, i want the cut to be the 'outside' of the circle?
