flak monkey
| posted on 15/1/11 at 09:30 PM |
Grommet type anti vibration mounts
I need to find some of the grommet type anti vibration mounts but dont know what the proper name is for them... usually in 2 halves with a metal tube
through the middle.
Anyone know the proper name, or know of a place to get them from? I need ones with a 6mm or 1/4" hole in the middle and some with 3/8"
holes...
Sera
http://www.motosera.com
RichardK
| posted on 15/1/11 at 10:50 PM |
Dunno what they're called either but most often seen them on bike fairing/cowlings, is this like what you mean?
linky
Rich
Gallery updated 11/01/2011
| posted on 15/1/11 at 10:55 PM |
Sounds a bit like megi bushes might do the job. If you want them threaded you might be looking for well nuts.
RazMan
| posted on 15/1/11 at 11:58 PM |
http://www.contitech-megi.com/pages/megi/product/product_en.html
Raz
| posted on 16/1/11 at 11:59 AM |
Sounds like what you want is similar to a classic Mini top radiator mounting bracket fixings, they used a 1/4"UNF bolt ? Can you not use a
standard cable grommett with a crush tube fitted?
flak monkey
| posted on 16/1/11 at 05:53 PM |
Thanks chaps. Given me a few options anyway.
Those are the sort Mel. I could just use grommets with a crush tube, but the mounts I was thinking of were slightly stiffer material.
Sera
| posted on 16/1/11 at 07:12 PM |
Poly bush type material?
flak monkey
| posted on 16/1/11 at 08:21 PM |
Not quite that stiff. Just a harder rubber thats all. I need some for various tank mounts on the bike to stop the oil and fuel frothing
Sera
matt_gsxr
| posted on 16/1/11 at 10:38 PM |
David,
Nissan Pulsar has something similar on the intercooler mount (guess how I know). It is basically a rubber grommet with a bolt through it. It mounts
into a hole. Once the bolt is through the grommet it can't get out of the hole.
You could do the same thing. "anti vibration grommet" throws up a couple of hits.
Matt
p.s. that inlet plenum lid is a nice chunk of metal. Thanks again for that tip.
[Edited on 16/1/11 by matt_gsxr]
| posted on 17/1/11 at 07:41 PM |
Small fuel pump mounts any good?, some have 6mm male threads on each end. Vectra airbox use a similar item
Neville Jones
| posted on 18/1/11 at 09:34 AM |
sounds like the top rad mounts on an old Mini. 1/4". Should be available from Minispares.
