Author: Subject: holesaw
femster87
posted on 3/3/11 at 08:36 PM Reply With Quote
holesaw
Anybody know where i can buy a range of diamond grit holesaws for cutting fibreglass
posted on 3/3/11 at 08:55 PM Reply With Quote
I don't. But I just used normal ones from toolstation.
contaminated
posted on 3/3/11 at 09:05 PM Reply With Quote
And me from B&Q. Also cut through aluminium.
Tiger Super Six Independent
www.southernkitcars.com
HowardB
posted on 3/3/11 at 09:13 PM Reply With Quote
if you have to have diamond grit ones, there are some that can be bought from B&Q for doing tiles, also there are those for cutting bricks,...
As noted for a few holes standard saws are ok.
Howard
femster87
it seems to be quite rough when it cuts on aluminum, really don't want to crack them
Steve Hignett
posted on 3/3/11 at 09:24 PM Reply With Quote
Sorry to not answer your question but respond anyway, but:
I find the Starret range of holesaws to be superb and very clean cutting through FG and Carbon etc...
posted on 3/3/11 at 09:27 PM Reply With Quote
I thought the general rule with GRP is that you actually don't want a super sharp drill and that a slightly blunt one works better because it doesn't chip the gel-coat? Or maybe that's urban myth.
austin man
posted on 3/3/11 at 09:32 PM Reply With Quote
masking tape is a must, cut the hole undersize then make good with a dremmel with sanding bobbin on or cut out with the dremmel
big_wasa
posted on 3/3/11 at 09:38 PM Reply With Quote
I only used a cheap set for mine and they did the job just fine.
femster87
posted on 3/3/11 at 09:39 PM Reply With Quote
thanks
40inches
posted on 3/3/11 at 09:54 PM Reply With Quote
I used a standard metal cutting holesaw, cutting through 2 layers of masking tape and joining the holes with this, using a fine metal blade.
posted on 3/3/11 at 10:44 PM Reply With Quote
That certainly works for numberplates, blunt drill doesn't crack the top layer of plastic but a sharp one does.
The Venom Project
posted on 4/3/11 at 12:35 AM Reply With Quote
A tip for holecutting Fibreglass
I found using the drill in reverse made a super clean cut instead of ragging a hole through in forward drive.
I did all my steering and wishbone holes like this.
Nick
It's not that i'm lazy, it's that I just don't care.....
