Author: Subject: Bits still left for sale - inc zx12 motor, R888's
eznfrank
posted on 13/7/11 at 12:52 PM Reply With Quote
Right, I've now managed to catch my breath following the initial onslaught of requests for bits and pieces, but I still have left the following:
ZX12 A1 Engine with shortened sump, uprated clutch springs and modified pickup, includes ECU, regulator and a modified engine only loom. The loom has had all the lights etc stripped out, the loom was modded by me and does work but I have to admit it's not the best wiring. I can include a very clear copy of the wiring diagram. Also includes ignition barrel with two keys, avoiding need for resistors etc. The engine was sourced from Malc at Yorkshire engines and from memory has 2300 miles on it. Looking for £1450
Ceramic coated steel manifold made by S&S headers in the states. Made for a ZX12 but according to paperwork would fit blade, 11R. Includes collector. £250 (cost closer to £500 with import duty from US) these are not your average manifold, top quality kit.
Power Commander III for above £125
Clocks for the above with a custom one-off ali fascia made by Martin Keenan - £130
75mm ITG filter and baseplate for the above £70. Could use basplate as template to adapt to fit most BEC's
Prop adaptor for zx12 £35
Would consider doing the above as a package for around £2,000.
Wheels & tyres. Set of black multi spoke 15" alloys with SG compound R888's. Brand of wheel is unknown although the tyres are the main part of the cost. Have been fitted and slight paint rubbed off around wheel nut holes. Never used other than wheeling in and out of the garage. £500
Prop modified by MK, will check length tonight £60 - Provisionally sold
13" Mountney steering wheel, with a free Sierra steering wheel thrown in to get you through IVA. Can include boss adaptor for the Mountney, and horn adaptor. £45
MK Reverse box, ring gear, cable and button. Never used £250
other bits and pieces I will put a price on asap but feel free to make an offer in the mean time.
Battery
Leather look handbrake gaitor and chrome surround
Tonneau boot cover for MK to suit roll bar without back stays
Immobiliser
handbrake cable
Fan
[Edited on 13/7/11 by eznfrank]
eznfrank
posted on 20/7/11 at 01:05 PM Reply With Quote
Lots of bits still left, will take £1300 for the engine and £425 for the alloys with R888's.
Open to sensible offers on the other bits and bobs. if it's not all gone in next week or so it might have top be the dreaded fleabay!!
Fan and prop - SOLD
eddbaz
posted on 20/7/11 at 03:41 PM Reply With Quote
u2u sent mk reverse
hiflow
posted on 29/7/11 at 06:44 AM Reply With Quote
sent you message regarding engine
