mistergrumpy
| posted on 26/7/11 at 10:43 AM |
Rose Joints
Has anyone any idea of a rose joints shank length? Is it in comparison to anything else, for example I know that the diameter of the actual rose joint
bore is generally the same as the diameter of the threaded shank.
I've bought some M12 ones from McGill last night for the upper wishbone but can't ring them to ask as my cordless phone battery is now
dead at the moment
blakep82
| posted on 26/7/11 at 10:58 AM |
i bought some from him years ago, and the shank length is 35mm, so unless he's changed supplier...
edit: thinking about it, they might have been 1/2" unf right enough, but i would think they'd be the same
[Edited on 26/7/11 by blakep82]
________________________
mistergrumpy
| posted on 26/7/11 at 11:06 AM |
Around 35mm then? That'll do for a start.
blakep82
| posted on 26/7/11 at 11:11 AM |
in fact, he emailed me a catalogue in 2007, which i still have a cody of, gives all the dimentions of all the rod ends he stocked then. M12 is
actually quoted as 32mm minimum. u2u an email address, and i can forward it if needed?
mistergrumpy
| posted on 26/7/11 at 11:12 AM |
Thanks Blake.
