fazerruss
| posted on 10/9/11 at 10:08 AM |
self adhesive non slip stuff
Does any one know where I can get some self adhesive non slip sand paper type stuff like what is on the top skate boards and edges of comercial steps
ect? Its for the bottom of my car lift.
At the moment it has some rubber matting that I glued to it but it has stretched and looks crap.
I need 2 pieces 1340 x 350mm any ideas? oh and must be cheap cos Im tight!
"if assholes could fly this place would be an airport"
balidey
| posted on 10/9/11 at 10:14 AM |
I bought some grip tape from ebay, just a few quid.
But for the size you want and it needing to be cheap, then some emulsion paint mixed with sand will cost next to nothing.
We have industrial grip flooring installed at work and its just polyester resin mixed with a carbide grit.
Dutch bears have terrible skin due to their clogged paws
trextr7monkey
| posted on 10/9/11 at 10:21 AM |
IKEA used to do it and it was much cheaper than anywhere else.
atb
Mike
fazerruss
| posted on 10/9/11 at 10:23 AM |
Never thought of the sand on paint idea, Ill do that if I have no joy finding what I want. Only problem is ill have to remove all the old contact glue
first. What ever I do it needs to be neat and tidy cos its my home workshop and Im a perfectionist.
carlknight1982
| posted on 10/9/11 at 10:31 AM |
you can buy non slip paint and paint it straight on, we used to do it yearly at renault for the lifts,
Logic will get you from a A to B
Imagination will take you everywhere.
van cleef
| posted on 10/9/11 at 11:00 AM |
my local building supplier sell's it coming in 2" roll's in yellow and black stripe's at roughly a fiver a roll.
| posted on 10/9/11 at 11:53 AM |
I used a piece that was left over when my MIL had a wheel chair ramp fitted the first time I used some , so it might be worth checking with your local
mobility shop . After stripping and rebuilding the car I brought some from a boat chandlers , available in several colours and about 6" wide .
