djtom
| posted on 12/9/11 at 05:03 PM |
What are these?!
I bought a job lot of tooling from an engineering workshop that was closing down and I'm selling it bit by bit on eBay.
I've just come across some items that I don't recognise. They're about 2" long, 1 1/2" wide and look like big thread
taps, but the grooves are parallel, not spiral.
Any ideas (and are they worth anything!)?
Tom
  mystery tools
| posted on 12/9/11 at 05:17 PM |
The one without grooves looks like a reamer.
The Shootist
posted on 12/9/11 at 06:26 PM |
Hobbs
No wait! No spiral?
Roughing mills. definitely.
| posted on 12/9/11 at 07:41 PM |
quote: Originally posted by The Shootist
No wait! No spiral?
I though the flutes would be spiral on a roughing mill? Also the "teeth" would have to be staggered otherwise you really would produce a
rough finish!
The Shootist
| posted on 13/9/11 at 05:28 PM |
rough finish!
Depends on intended usage. Some milling is done with the cutter at an angle across the workpiece. With a roughing mill material removal is top
priority, surface will be cleaned up by a later pass with a finishing cutter.
They seem to be for milling as i think I see an internal taper.
Ahaa! They are "Thread Mills" http://www.carbidedepot.com/formulas-threadmilling.htm
djtom
| posted on 18/9/11 at 06:09 PM |
Yes, I am coming to the conclusion that theyy are thread mills. That would explain why the collection of them that I have acquired have different
pitches between the teeth....!
Thanks for all input. Anyone want to buy them?
Tom
